I have a 1999 with 50,000 miles on it and I need to change the oil. Do I really need to do the decarb procedure on the motor? What are the pros and cons. Thanks ahead of time.
If you are talking the Seafoam method, I would do it. It can't hurt. A ton of junk comes out the tailpipe which can't help the car staying inside. I had a dealer do it for a Dodge and it made a significant improvement in my milegae (2 MPH). It obviously cost more than a can of Seafoam but since you're going to do the oil might as well do it now.
But on the other hand the engine ain't gonna seize up tomorrow since you didn't do it.
mark it up as PREVENTATIVE maintenance that is pretty cheap to do.
Yes, the Seafoam method is what I am talking about. The only thing that concerns me is stalling of the engine on the Decarb. procedure listed under C5 Tech Tips.
I did it and it sure didn't hurt anything ....... I just turned engine off.....you don't have to stall it.
The smoke issue is pretty embarrassing. Even if you get out of your neighborhood and drive it everyone will be staring and not with the typical "look at that hot car."
Now I do it in the afternoon or evening, let the car sit overnight and get out and drive it before daybreak so no one notices. Then I change the oil and wash all the black crud that is stuck to the rear of the car.
You will be amazed at what comes out the exhaust after a top end cleaning.
Is there a certain milage thing involved in this, where you would do a decarb. Cars with low miles need it or not - its 99 though, with 23K miles. Does any of this hurt the valves, intake, rings etc. It seems pretty harsh chemicals to be used in a High end car.
I was told by an auto parts specialist. He said why use Seafoam for Decarb, why not use the product mainly designed for car engines... So, he suggested the "PROFESSIONAL 3-STEP FUEL SYSTEM MAINTENANCE KIT, by Berryman CHEMTOOL. It consists of 3 cans in a box. Price: $24.98 from Kragen.
Has anyone come across this product, used it, or know anything about it Vs Seafoam....?
3M makes a cleaner kit that costs about $60 including the connector adapter. IT WORKS. I had a '91 Coupe A4 with 97K on the clock, ran the 3M cleaner through the injector rail and cleared up rough idle and bumped fuel economy a solid .8 mpg.
I bought a gallon of Seafoam at O'Reilly for $43 and change.
I have a '98 M6 coupe now and just put 12 ounces of Seafoam in a half full fuel tank and 8 ounces in the crankcase. Going to run it for the next three or so operating hours, drain the oil, and put in a new filter. I have about 30 minutes on the engine so far and can't tell anything yet.
