Z06 bucking and surging?
Old Jun 26, 2006 | 10:19 AM
Highroller's Avatar
Highroller
Default Z06 bucking and surging?
I checked everything cant find the problem, my 03 Zo6 has developed a surge, I’ll be driving down the road in any gear and it will start to hold back, surge. I’ve changed the plugs. Plug wires, cleaned everything in the air intake, changed the gas, changed brakes and rotors, and to make things worst no codes at all, anyone got a suggestion.
Old Jun 26, 2006 | 10:33 AM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Did you change anything around the MAF area? Like a new cold air tube or any loose connections around the MAF. Some ideas to check on.
Old Jun 26, 2006 | 11:21 AM
Highroller's Avatar
Highroller
It has a Blackwing, but thats been on it for 2 years and the car only has 9k on it
Old Jun 26, 2006 | 11:32 AM
HeadHunter1's Avatar
HeadHunter1
Get some contact cleaner and clean the wires in the mass airflow sensor. Do NOT touch them, just spray them carefully. You want to make sure you use a quality contact cleaner that leaves no residue. Some people have used brake cleaner, but I am more comfortable with contact or circuit board cleaner.
Also, check for air leaks after the mass airflow sensor. I have also seen this behavior with bad O2 sensors but would check/clean the the MAF sensor first.
Old Jun 26, 2006 | 11:45 AM
DropTheTop's Avatar
DropTheTop
Default Me too...
That's weird, my 98 just started doing that, too. It's very strange how it happens. I'll get in and take a short drive - everything's fine. Turn the car off, go inside a store. Come out a few minutes later, start er up, and it's running rough. Go to drive away, and it surges like crazy. Then in a few moments - gone. AND, it doesn't do it all the time. I'm gonna start troubleshooting this weekend when I have 5 days off. I'll let you know if I come up with anything.
Old Jun 26, 2006 | 12:01 PM
Highroller's Avatar
Highroller
I cleaned the MAF sensors and the thottle body with carb cleaner still bad
Old Jun 26, 2006 | 12:03 PM
Highroller's Avatar
Highroller
Just about the same problem but the engine is running fine and it doesn't go away no matter how far I drive.
Old Jun 26, 2006 | 02:01 PM
dwjz06's Avatar
dwjz06
Dogface
Do you still have the stock air box? If so take the Blackwing off and try the stocker. If this solves your problem you know what to do with the blackwing right?
Old Jun 26, 2006 | 02:59 PM
davette's Avatar
davette
90% of surging is caused by unmetered air that is leaking upstream of the MAF, unless you have a large cam. I bet you have a leak somewhere between the MAF and throttle body. Check ALL clamps for tightness. I had a very small leak and my car would buck on the freeway. Once I found the small leak, problem solved. I have a blackwing also. They tend to get loose and need to be tightened every six months!
Old Jun 26, 2006 | 03:40 PM
c5vette_dallas's Avatar
c5vette_dallas
i friggin love this place
Old Jun 26, 2006 | 04:00 PM
DropTheTop's Avatar
DropTheTop
I recently installed the Blackwing, so I'll definately be checking for leaks first. Thanks.
Old Jun 26, 2006 | 05:30 PM
Highroller's Avatar
Highroller
Took the blackwing off as you suggested and in a 10 mile trip the surging seems to have gone away, I'll try a longer trip tommorrow, checked all the clamps they were tight, I've had the Blackwing on for 9k miles and 2 years and now I have a problem??? Why no codes???
Old Jun 26, 2006 | 06:57 PM
hotwheels57's Avatar
hotwheels57
I installed a BLACKWING on my '04 Z16 last weekend. Everything looked all tightened up, but closer inspection (with a flashlight) of the silicone hose connector at the throttle body revealed a problem.
The thin stainless worm drive hose clamp tightened down and squeezed out the very bottom of the hose leaving a very small almost undetectable gap. I applied a very light coating of grease and it was slipped on again. The clamp has to be very close to the throttle body or it'll slip off. My solution will be the special "t-bolt" clamps for all connections...they're wide and won't loosen up on the slippery silicone.
Old Jun 26, 2006 | 07:55 PM
Blue Angel's Avatar
Blue Angel
I sometimes get a very light "surging" when cruising at low RPM/high vacuum... like under 1500 RPM, in any gear. It doesn't happen often, and the car runs like a champ overall.
Could this be the same issue? If I remember correctly, the problem existed even with the stock intake before I installed my Halltech Stinger? I could be wrong...
Old Jun 26, 2006 | 11:40 PM
05-STi's Avatar
05-STi
I had similar issues of surging. I recently installed a catch can to catch oil vapors getting to my Throttle Body from my PCV. My problem was fixed when I removed the Throttle Position Sensor on the passenger side of the throttle body and cleaned some oil residue off of it with rubbing alcohol on the end of a q-tip. Now that I have the catch can in place I don't have oil getting in the throttle body and the probelm of surging has not returned. The throttle position sensor appears to have just not been acurately sensing the throttle position.
Old Jun 27, 2006 | 08:34 AM
Highroller's Avatar
Highroller
I put the complete original air system back on and last night took a 50 mile ride to the shore, problem solved , after living with this for over a month every thing is perfect. I inspected every part that was removed and didn't find anything wrong, next move will be to re-install 1 part at a time and see if I can find the part thats bad, hope it's not the Blackwing.
Old Jun 27, 2006 | 11:45 AM
dwjz06's Avatar
dwjz06
Dogface
I thought that would solve your problem. Look for a complete Cold Air Package next time around. The big power gainer seems to be the Callaway Honker system at this time. Good Luck.
Old Jun 27, 2006 | 02:36 PM
davette's Avatar
davette
Glad you were able to narrow down the issue. Even if it is just a small leak, you will get surging. The issue I had with mine was not the blackwing itself - but the connections from the MAF to the Throttle body. The airbridge (part that goes over the radiator plastic crown piece) seems to be a culprit in a lot of cases, including mine. It had started to crimp so it would not make a full airtight seal. I went back to the stock airbridge and it was fine. So, basically, I am running stock parts except the blackwing filter. Seems to work well.
To Z06 bucking and surging?
