Running Light Problem
Old Jun 26, 2006 | 02:55 PM
C-$'s Avatar
C-$
Default Running Light Problem
First off my front running light keep acting up. I replaced the bulbs but one of the two usually fails within a few days. After noticing this the problem fixes itself and then fails again. I am thinkin there could be a short somewhere or a loose ground wire? Any input on this would help. The car is a 1998.
Old Jun 26, 2006 | 02:59 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
more that likly your connector is corroded. Try cleaning it with electrical contact cleaner. Make sure you are getting a good connection.
Old Jun 26, 2006 | 03:17 PM
FASST LN's Avatar
FASST LN
Wow! I'm having essentially the exact same problem. What I don't understand is why the bulb works when I use my parking lights, but fails to work when I use my turn signal or DRLs. It is the same bulb!!
Went to some trouble to replace the bulb this weekend. After swapping in the new bulb, the wifey clicked the turn-signal for me and everything worked great. When I walked to the front of the car to move the ramps (and the car was idling), I saw the bulb go out for the DRLs. Tried the turn-signal and it failed to work. Don’t know why.
I tried cleaning the contacts with electrical cleaner but that apparently had little effect.
Any help?
2000 Coupe
Old Jun 26, 2006 | 04:52 PM
C-$'s Avatar
C-$
[QUOTE=FASST LN]Wow! I'm having essentially the exact same problem. What I don't understand is why the bulb works when I use my parking lights, but fails to work when I use my turn signal or DRLs. It is the same bulb!!
I have the same issues. Works when they want to. The turn signal will also sometimes work though but no running light?...
Old Jun 26, 2006 | 05:12 PM
1965imp's Avatar
1965imp
I had a simalar problem,but only on the drivers side. I checked everything and found it to be corroded wires that run inside the plastic front bumper. I have stressed before that everyone that owns an early C-5 should have the Y-Platform sevice manuals. They have good electrical trouble shooting guides. Mine is a ' 98 too.
Old Jun 27, 2006 | 10:04 AM
C-$'s Avatar
C-$
Thank you for the help. Where can I get one of those manuals?
Old Jun 27, 2006 | 11:48 AM
white90conv's Avatar
white90conv
There are two filaments in the bulb - one for DRL's/turnsignals and another for the parking light and two circuits. So one can work without the other. You can get a good price on a manual from Fred Beans,and advertizer on this site.
Old Jun 28, 2006 | 12:53 PM
C-$'s Avatar
C-$
Thanks everyone for your help...I believe I have solved my problem. Again thanks for the quick responses and info.
Old Jun 28, 2006 | 02:27 PM
FASST LN's Avatar
FASST LN
So how did you solve the problem?
(Inquiring minds want to know)
Old Jun 28, 2006 | 07:00 PM
DeeGee's Avatar
DeeGee
[QUOTE=C-$]
I'm a little confused when you say you have parking but no turn signals/DRLs. The way the bulb works is that it has two live feeds and a common ground
There are 3 wires running to the bulbholder
a blue/white wire which is the live feed for the turn signal function
a brown wire which is the live feed for the parking light function. This also powers the DRLs. You can disable DRLs and leave just parking by pulling the A2 fuse. this would help to troubleshoot.
a black wire which is the common ground.
So, it is possible that you can have a problem on the live side of either circuit and still have the other function working.
Old Jun 28, 2006 | 08:29 PM
VETTING's Avatar
VETTING
So are you saying that the brown wire is for the DRL's? I've been looking at schematics because I would like to use a led called switchback from autolumination.com but I'm not sure if they will work on our cars. Sorry about "highjacking" the thread!
Old Jun 29, 2006 | 12:23 AM
DeeGee's Avatar
DeeGee
To be precise the DRLs can activate both circuits. The only way to inhibit them is to pull the fuse or do the relay mod.
My Vert is modified for UK standards. I have a tap off the side repeater lamp circuit which drives a white parking light fitted into the Euro headlights. The brown wire is snipped leaving just turn signals on the amber bulb. The A2 fuse is pulled to inhibit the DRLs. However, if I put the fuse back I get amber DRLs until I pop up the headlights. On park or low or high beam I then just get white lights.
When I take it to UK I'll do the permanent relay fix.
Old Jun 29, 2006 | 02:41 PM
C-$'s Avatar
C-$
Just Cleaned up around the ground wires. Hopefully that will do the job.
To Running Light Problem
