A/C compressor
Old Jun 27, 2006 | 07:31 PM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
Default A/C compressor
Hello, I posted a forum the other day about my A/C light flashes when I turn it on. Compressor will not turn on. I spoke to the orig owner of the car, he states he replaced the compressor last year with a rebuilt .
Do you think this rebuilt when bad already? Will the light flash if it does?
I found new ones on Ebay for 320.00, what do you think? I'm getting ready to leave town for 3 weeks and I know this will drive me crazy
Old Jun 27, 2006 | 07:54 PM
rws.1's Avatar
rws.1
The light flashes when the system is low on R134a....
The question is why after a replacement compressor a year ago is it low??
Do you know if they put fluourescent dye in it when they changed out the compressor? If they did it should help you id the source of the leak.
Old Jun 27, 2006 | 07:59 PM
pauly1119's Avatar
pauly1119
Hello, I just opened the freon cap and I can see that someone used the
fluourescent dye at one time, its under the cap. I checked all the lines and see none. Does it stay in the system. I know nothing about A/C systems.
Old Jun 27, 2006 | 08:46 PM
rws.1's Avatar
rws.1
Yes the freon (R134a) should stay in the system. If there are no visible leaks and only some dye under the cap, perhaps the fill valve is the source of your leak or perhaps it is just slightly low. Because of car vibrations, automotive sytems can develop leaks at connection points.I would take it to a local garage that advertises that they service air conditioners and ask them to test the system. If you bought it locally ask the buyer where he had it replaced....
Old Jun 27, 2006 | 08:52 PM
pauly1119's Avatar
pauly1119
thanks I will
Old Jun 28, 2006 | 06:37 PM
pauly1119's Avatar
pauly1119
Default update on A/C
Okay spent 8 hrs at a A/C repair shop. Hard wired compressor blows icecold so thats not it. Put the dye in no leaks. Ran a complete computer check no codes, with one of those 4K computers. Put a new high pressure sensor in and still no A/C. There is no power from the fuse box on. They jumped the system from the fuse box. I just drove the car home because I'm going away for almost 3weeks. Just wondering can it be the headunit or maybe even the computer. My steering locked up the same day, which is fixed now. Can it be related.
Thanks Paul
Old Jun 28, 2006 | 10:06 PM
BrentNY's Avatar
BrentNY
The computer was one poss in my situation but it turned out to be low pressure sensor as I told you before.
Old Jun 28, 2006 | 10:13 PM
pauly1119's Avatar
pauly1119
can you tell me where it is? I was unable to locate it.
Old Jun 28, 2006 | 10:29 PM
BrentNY's Avatar
BrentNY
It's on the pass side just to the left of the coolent res. on the A/C rail. It's a plug n play because it has a shraeder valve, you dont have to depressurize the system to change it. Good luck with this mess. I hope it works for you, I struggled with a solution for a year with the stupid blinking light. Just for the hell of it change out the #34 micro relay too.
Old Jun 28, 2006 | 10:39 PM
pauly1119's Avatar
pauly1119
Thanks for the help, but I did change that sensor with a new chevy one and I did change change relay#34. I thought there might be another one some place. ?????????
Thanks for your time.
Old Jun 29, 2006 | 07:13 AM
BrentNY's Avatar
BrentNY
OK, i didnt realize that because in your post you said they changed the high pressure sensor. If you changed the low pressure sensor, then it might be the PCM. Then I'm done. Good luck and let me know.
Old Jul 9, 2006 | 02:20 AM
pauly1119's Avatar
pauly1119
Hello, sorry it has taken so long to reply, but I have been in Hawaii on vacation, but what is a PCM? Is this the computer?
Thanks in advance.
Old Jul 20, 2006 | 06:42 PM
pauly1119's Avatar
pauly1119
Hello, is the PCM the computer?
Old Jul 20, 2006 | 07:50 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Yes it is.Did you fix your A/C yet? I'm having the same problem,When you push the A/C button, It just blinks and goes out and no A/C...............................Paul
Old Jul 20, 2006 | 09:05 PM
pauly1119's Avatar
pauly1119
No, it is still not working. I had it at a A/C repair shop for 8 hrs, they could not find the problem. No freon leaks, compressor is okay, changed the high pressure sensor. temp sensor is working. All of these things will cause the light to flash, I hope yours is a easy fix. I quess I'm going to have to bring mine to Chevy.
Old Jul 20, 2006 | 09:38 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
swap out the a/c control head unit, if you were local I'd swap in a spare to eliminate that option
Old Jul 20, 2006 | 10:21 PM
pauly1119's Avatar
pauly1119
thanks I will give it a try
Old Jul 21, 2006 | 05:20 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
What exactly is the a/c control head unit? Is it the part in the dash with the buttons and display? Do you have an extra one to sell? I'm not that far from you.I have the dual zone a/c & heat..............................Paul
Old Jul 22, 2006 | 08:01 PM
pauly1119's Avatar
pauly1119
Hello, the control head is the A/C control in the dash, no I don't have a extra one forsale, I would have to purchase one. My vette also has the
To A/C compressor
