Driver's side door electrical problem
Old Jun 28, 2006 | 07:02 PM
vette98c5's Avatar
vette98c5
Default Driver's side door electrical problem
My driver's side window and lock would not work so I checked the fuses and they were ok. Then I took apart the door panel and found out on another post to try squeezing the wiring harness between the door and the body. While I was having the problem all of my guages went nuts too. Squeezing the wiring harness worked. My question is what is the proper way to fix it. Or should I just leave it the way it is? I also wonder if the door has it's own wiring harness or if it runs all the way to the computer. Any help would be appreciated
Old Jun 28, 2006 | 09:26 PM
ge2001's Avatar
ge2001
I have an 01 with the same problem from time to time. I have reinserted the connector to resolve the problem but it eventually comes back. I would also like to know if there is a permanent fix. Thanks.
Old Jun 28, 2006 | 09:57 PM
vette98c5's Avatar
vette98c5
When you say you reinserted the connector, which connector are you refering to so I can try it if I have not already done it. thanks
Old Jun 29, 2006 | 09:06 AM
ge2001's Avatar
ge2001
I believe it is the same wiring harness between the door and the body as you described. If I recall it is right after where the wires come from the door. I real PITA to get to lying on your back.
To Driver's side door electrical problem
