Help Please, Tools Needed.
Old Jun 28, 2006 | 07:53 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Default Help Please, Tools Needed.
Hi,
I just purchased my 2003 Z06 and waiting for my shop manual
In the mean time, I wanted to replace my manual trans fluid and diff. fluid. Would one of you kind souls please tell me what size allen? I need to do the job(s), please
Thanks in advance,
Chris
Old Jun 29, 2006 | 08:22 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I was just about to say 10mm but then I realized I also have a 12mm allen wrench and I can't remember which one I used.
Old Jun 29, 2006 | 02:54 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Well, lot of help you were! LOL
jeff
Old Jun 29, 2006 | 03:07 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Last time I checked it uses a socket drive for the drain and fill plugs. 1/4 or 3/8ths drive.
TTT for ya
Old Jun 29, 2006 | 03:49 PM
Chris_G's Avatar
Chris_G
Thanks folks...a 3/8th drive fits the drain plug but I can't figure what I need for the fill I did try a 3/8th allen and it was too small
Old Jun 29, 2006 | 04:15 PM
VetteDrmr's Avatar
VetteDrmr
3/8" for the tranny drain and fill plugs. There might be some crud build up in the fill plug that needs to be scraped out.
The diff drain and fill plugs take male hex (i.e. allen) sockets, but I can't remember right now (fat lot of help I am, huh!).
BTW, remember to add a bottle of GM limited slip additive to whatever fluid you fill with.
I'll try to remember to go find it tonight when I get home.
HTH, and have a good one,
Mike
Old Jun 30, 2006 | 11:02 PM
Chris_G's Avatar
Chris_G
C'mon you guys, would you please help me out.
Old Jun 30, 2006 | 11:39 PM
VetteDrmr's Avatar
VetteDrmr
Sorry about the delay: I went out and checked, the differential plugs take a 3/8" hex socket. Only about 20 ft-lb on the torque.
Mike
Old Jul 1, 2006 | 05:52 PM
Chris_G's Avatar
Chris_G
Default Thanks Folks!
I got the trans, diiff, and oil changed today
I did not realize that there was a sensor in the trans fill plug
Thank you all so very much for your help. Now, I have to get the car started. This is sad, I bought this car three weeks ago and have yet to drive it
Old Jul 2, 2006 | 11:08 PM
VetteDrmr's Avatar
VetteDrmr
Oops, my bad on that one. I forgot you have a Z06; the sensor in the fill plug is a temperature sensor. You won't see it displayed on the DIC unless the temps get to a warning level. Then it's displayed instead of the engine oil temperature.
Glad you got everything done; now go have some fun!
Have a great 4th,
Mike
To Help Please, Tools Needed.
