Engine Stall under full acceleration
Old Jun 29, 2006 | 12:29 PM
C5FLORIDA's Avatar
C5FLORIDA
Default Engine Stall under full acceleration
cruising at about 50-60 MPH hit the gas all the way, car accelerates to 80MPH and then just sits there as if its speed limited, for about 5-10 sec. and then resumes accelerating, all the time with gas pedal fully depressed.
This has happend already many times, also with traction control off.
did this happen to you?
any idea what is causing this?
thanxs
Old Jun 29, 2006 | 01:40 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Auto tranny? Is it shifting?
Has the computer been re-programmed?
Is it hitting the red-line?
Old Jun 29, 2006 | 02:47 PM
C5FLORIDA's Avatar
C5FLORIDA
It an automatic, no redline hitting, and it shifts fine, computer has not been reprogrammed by me, but i bought it used
Old Jun 29, 2006 | 03:02 PM
screw991le's Avatar
screw991le
Humm, have you done a search here.
TTT for ya
Old Jun 29, 2006 | 03:34 PM
RED99's Avatar
RED99
These C5's has so many sensors, you should use it to your advantage. Do a full scan and you will more than likely see what the problem is. But it sounds like maybe ignition retard. Are you hearing any knocking or pinging?
Old Jun 29, 2006 | 08:11 PM
C5FLORIDA's Avatar
C5FLORIDA
not that im aware of, how can i do a full scan?
Old Jul 13, 2006 | 01:30 AM
C5FLORIDA's Avatar
C5FLORIDA
Default Its the transmission
thanxs
I shall have an exact diagnosis in the morning, thanxs for elp
Old Jul 13, 2006 | 09:23 AM
Face's Avatar
Face
Cat over temp?
To Engine Stall under full acceleration
