Check Engine Light P0410
Old Aug 31, 2001 | 12:42 PM
ddawson's Avatar
ddawson
Default Check Engine Light P0410
P0410 AIR System-B.
I've gotten this twice in two days. After clearing it goes away for awhile.
What does this one mean???
Old Sep 3, 2001 | 06:09 PM
WHY2KRAG's Avatar
WHY2KRAG
Default Re: Check Engine Light P0410 (ddawson)
I got the same indicator and I checked out the air filter intake and it was coated with sand. Gave it a few taps to losen off the sand captured on the outside of the filter and whalaaa check engine indicator went off. I might add that this happened a few times and I just kept clearing the code because I could not find anything wrong at the time I never thought about air restriction to intake MAFT Hope this helps you out . :cheers:
Old Sep 3, 2001 | 10:49 PM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Hi there,
This is telling you that you have a problem with the air injection system within your engine.
It is not giving you a bank, so it could be either the pump or the control relay.
This should be diagnosed, and corrected. It will not cause any driving issue, just cold start emissions, best to you, c4c5
To Check Engine Light P0410
