Hesitation from dead stop
Old Jul 2, 2006 | 04:05 AM
VIslndr's Avatar
VIslndr
Default Hesitation from dead stop
I have a 99 A4 coupe (Z51 susp) with the following mods: Blackwing w/ice box, LS6 manifold, carbon airbridge, B&B Bullets, 3.42 gears and a street tune with no codes. Here is the issue – from a dead stop when go to WOT, there seems to be a lag in acceleration before I am pushed back in my seat and I can’t spin my tires (BFG Eagles F1). Also, when in idle and blip my throttle, I notice my RPMs don’t rise or fall immediately. My tuner has looked at everything and there are no problems with my MAF or any other readings. HELP!!!!
Old Jul 2, 2006 | 12:28 PM
brookman's Avatar
brookman
Did you disable the traction control - by putting the car in competition mode?
Old Jul 2, 2006 | 12:41 PM
Smokin Joe's Avatar
Smokin Joe
I know it seems simple, but check the spark plugs and plug wires.
Old Jul 2, 2006 | 04:00 PM
VIslndr's Avatar
VIslndr
I have tried with Comp mode and with traction off, no luck. I have not checked the plugs or wires, I'll try that next. Thanks for the feedback!
Old Jul 10, 2006 | 12:46 PM
VIslndr's Avatar
VIslndr
Some additional info if anyone else is suffering from this problem.
http://forums.corvetteforum.com/show....php?t=1437910
Old Jul 20, 2006 | 01:00 AM
VIslndr's Avatar
VIslndr
TTT
Old Jul 22, 2006 | 03:19 PM
VIslndr's Avatar
VIslndr
Replaced plugs with NGK TR55 and MSD wires. Seems to idle just a bit better, but no chirp Cleaned the MAF and TB too Throttle body was gunked up. My car has 44k miles and I don't know if it was every done. If you haven't done yours, I would recommend it.
To Hesitation from dead stop
