front anti-sway bar
Old Jul 19, 2006 | 01:01 PM
billiardcue's Avatar
billiardcue
Default front anti-sway bar
Is there any advantage to disconnecting the front anti-sway bay on a C5 for better traction - weight transfer at the drag strip?
If so can you just remove the four bushing bolts or should you disconnect the end links?
I want to leave the bar in place and disconnect / reconnect at the strip when changing tires.
Old Jul 19, 2006 | 02:33 PM
63Corvette's Avatar
63Corvette
Just disconnect ONE (1) endink.
Understand that the car will "tend" to severe oversteer (swap ends) with ONLY a rear sway bar and no front bar, but if drag racing is your thing, it's your car. (you can check on LS-1.com to see the F-body guys disconnect their front bars.....however, this is a "final tune' trick after all the other straight line factors have been used).
Old Jul 19, 2006 | 04:04 PM
billiardcue
Sure don't want to have handling problems, the walls on a drag strip are awful close.
Old Jul 19, 2006 | 05:09 PM
patton's Avatar
patton
St. Jude Donor '09
donot disconnect AH you will get weight transfer. just keep it straight
Old Jul 19, 2006 | 09:21 PM
billiardcue
I always run in 'competition mode'.
Do you run a C5 with the sway bar disconnected?
Old Jul 19, 2006 | 09:56 PM
Solofast's Avatar
Solofast
Disconnecting the front sway bar will indeed create a lot of oversteer, which is the last thing you need if you are deep into the power.
I can't understand why that would help improve 1/4 mile times or help in any way in drag racing... If you want to help improve acceleration you want equal loading on both rear tires. that means you want as much front roll stiffness as you can get and as little rear roll stiffness. That way, you are keeping the rear tire loads as close to equal as possible, which would help it track straighter and have less directional instability..
Somebody help me out here as to what the idea is. If the idea is that you want less weight in the front of the car, in particular in front of the front axle I can see how totally removing the front bar (it is heavy and ahead of the front axle) can actually increase the weight on the rear tires and reduce the overall weight of the car, but if you are going to do it you should also remove the rear bar too... Just disconnecting it is not going to help you in any way that I can see.
Old Jul 20, 2006 | 08:34 AM
billiardcue
I can't understand why that would help improve 1/4 mile times or help in any way in drag racing... If you want to help improve acceleration you want equal loading on both rear tires. that means you want as much front roll stiffness as you can get and as little rear roll stiffness. That way, you are keeping the rear tire loads as close to equal as possible, which would help it track straighter and have less directional instability...
What you say makes sense. Don't need instability as the two tracks I am trying to hook at are slippery and have enough instability on their own.
Removing the bar would certainly help in weight loss and distribution. Disconnecting or removing would allow the front end to lift easier and quicker transfering weight to the rear.
Old Jul 22, 2006 | 03:34 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
How would disconnecting or removing the bar do that? The anti-sway bar only affects side to side suspension loading when cornering.
To front anti-sway bar
