how do you go about changed clutch fluid on our cars, not just the way where u take some out of the top, but so i can get all the fluid out and put fresh fluid in..thanks
Unless you have a bleeder valve installed, which is not stock, you need to get to the slave cylinder and install one. Best case is you won't need to drop the drive system in order to get to it. Worse case is you gotta drop the differential, transmission and torque tube to get it.
this is why most just use a turkey baster and pull from the resevoir on top.
