C5 mods/bolt-ons help
First item! Mods are addicting, it's like eating chips, you can't just have one!
A cold air induction package, small cam, heads, and headers/cat back will get you there very easy. A high stall torque converter also would help. If you do the work yourself you might be able to stay within your budget (you can get some great deals from other members/supporting vendors).
Another easy way is to change your rear drive ratio. Going to a 3:73/3:90/4:10 rear. This is going to give you a great seat of the pants feeling.
BTW fill out your profile so people can make suggestions about supporting vendors who might be local to you.
Bob K.
I bought my 97 a couple of months ago and have pretty much the same goals. My car went 13.4X stock on a humid night in the 90*'s . Here's what I've done so far:
Culumn lock bypass- a must (read the sticky)
160* thermostat- optional
Borla Stingers- Sounds alot better
Vararam B2- Makes a good difference, cheap quality
Next are TSP headers which should be here today
After that I'm gonna put a converter and keep the stock gears.
Cam of choice
Besides a few more mods (ls6 intake, crank pully,tune) this "recipe" should get in the 11's on tires
So here's a list...
1) cold air induction: easy, rewarding
2) catback: easy, you get to learn how to raise the car, work your way around underneath, and so on; nice sound, a few ponies extra
3) headers: will give a significant boost in SOTP, work your way in the engine bay, and so on
4) next you got to decide if you want head/cam/tune or forced induction. Personally I feel that a Vette should remain a naturally aspirated design (no offence meant to all fellow CF members who took the other route) so I plan to get one of these. Make sure you have a tuner not too far, you will need.
5) Check out the Grond Chronicles, to see where this modding thing can lead you ! Not for the faint hearted !
In addition for true performance minded people who know that performance isn't only engine, you can do a big brake kit, plug in a Z06 suspension package, put in a monster stereo setup, etc
Have fun and tell us from time to time where you are on this project
With the above LT headers and Dr's should put into the lower limits of the 12's.
TC and gears will make a LOT of difference!
If you shop around, you can do both (at the same time of course) for around $1500. Add headers and a vararam and you'll be cooking
stock car was 2.73 car did a mid to high 13
450$ for a tci ssf3500 stall
500$ for a used 3.42 diff
100 $ vette doctors mail tune
car did 12.75 at 111mph
added texas speed headers removed cats $700 plus $500insatll
added ported tb $100
added ls6 intake $300
added mt 275.40.17 drag radials $450
car did 12.35 @110
personal if i was to do it again i would have gone with a bigger stall like 4000 and more gear 3.73 and a dry 100 shot car would be easy in the 11's
forget the ls6 intake its a waste unless going to heads and cam later ...
pulley is also to much labour to pay if thats all u are doing wait for h&c
Headers are nice but if you are paying labour on the instal its to much money for the gains..again unless you are going for heads and cam later
car did 12.35 @110
Wonder why you didn't see any gains from the headers? Got a part number on that converter?
Some people drill a series of 1 to 2 inch holes in the factory Lid along with a K&N airfilter.
Besure to drill the LID only if you go with option 2.
If you get a chance to look at the factory airbox you will be amazed. In my 99 there where only 4 small holes for air to travel into to feed the engine. I was horrified, but then agian the factory design must pass many federal standards related to noise, polution and many other things.
Good luck and get us some before and after results.
A Stock 99 running 12.27@104
I need to see this one run.
