What is the correct unit for my C5? What price should I be paying? Who should I get it from? I believe the local Pep Boys carries them for around $119 + $7 exchange.
I installed a Optima Red Top in my 1999 that I an transferring over to my new Z06. The Red Top will do you just fine and is a very dependable battery. I would also suggest (if you don't use your C5 much) a Battery Buddy or similair product to maintain the Optima or any battery during periods of non charging.
I got the Yellow Top from LAPD in the Forum mall. The Yellow Top is a bit more expensive than the Red Top, but it is a deep cycle battery, which makes it better able to handle being discharged and recharged repeatedly.
Bruce, I Emailed Optima with the same question, I have a 02 on order. They replied a red top model 34/78 . They said the yellw top is intended for marine applications and that the red top will take more recharges due to long storage than a regular batery. :cheers:
According to the latest Consumer Reports, The DURALAST GOLD (Autozone-$70) out-performed the Interstate ($96), Optima Red Top ($100+), AC Delco ($80) and Everstart (Walmart-$40) in that order.
Also, the free-replacement guarantee for Duralast is 36 months vs. 24 months for the Optima. The total warranty is 96 months (Duralast) and 72 (Optima)
For those in warmer climates, the Duralast number tested is 34DT-DGS.
For your location (North), the Duralast model # tested is 34DT-DGN.
