Transmission cooling question.
Old Jul 6, 2006 | 05:00 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Transmission cooling question.
This may sound stupid, but does the C5 have a transmission temp gauge? I’m talking about a 6 spd and if not where can I get one and how hard is it to install?
Thanks,
Clayton from Las Vegas
Old Jul 6, 2006 | 05:04 PM
AU N EGL's Avatar
AU N EGL
No they do not. The automatics do.
Old Jul 6, 2006 | 05:05 PM
Rhode Warrior's Avatar
Rhode Warrior
No, just automatic cars have them.
Old Jul 6, 2006 | 07:42 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
So what's involved with getting one for a 6 spd?
Thanks,
Old Jul 6, 2006 | 09:58 PM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Thanks,
If you get a high temp warning (as I often do at the track )....you hit the reset button on the DIC, and it tells you the temp. I've seen 275* many times in my Z06....
Old Jul 7, 2006 | 01:44 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Is this a transmission temp warning or oil temp? I’m looking for a transmission temp gauge.
Thanks,
Old Jul 7, 2006 | 07:15 AM
AU N EGL's Avatar
AU N EGL
The Oil temp will show in the DIC. Only a high trans temp warning will show up not the actual temp in the DIC.
The time and money spent to put in a trans temp gage might be better spend on putting in a trans cooler. Many of us have them for track days.
I have the GM T1 cooler system. Seperate trans cooler located in front of the radiator with a pump in the right rear wheel well. Manual switch in the old ash tray compartment.
Too many gages can be a distraction.
Replaceing the trans and diff fluids with synthtic helps keep those temps down too.
Old Jul 7, 2006 | 08:08 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
A transmission temperature sensor was added to protect the M12 from higher thermal stresses. The sensor warns the driver via the Driver Information Center with a TRANS OVER TEMP light if thermal loads become excessive, meaning that the transmission could be damaged if not allowed to cool down.
A Z06 does not show the actual temp???
I know the C5 does not. I added the T1 Tranny Cooler too. I turn it on after the fluids heat up a bit....
Old Jul 7, 2006 | 03:47 PM
Maineiac's Avatar
Maineiac
The Z06 shows the actual temperature....if there is a high temp warning. When you receive the warning on the DIC, hit the reset button and it tells you the TRANS. temp.
Old Jul 8, 2006 | 12:32 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Can this be set up in the regular C5? Since these cars are made with a lot of common parts, maybe the wiring is there and just a few things need to be added. Just a thought...anybody know?
Thanks,
To Transmission cooling question.
