Changing front turn signal unit?
Old Jul 8, 2006 | 08:05 PM
Derf's Avatar
Derf
Default Changing front turn signal unit?
Noticed a few small cracks in the front turn signal lens. How difficult can a change be? No idea how the cracks happened. Thanks
Old Jul 8, 2006 | 10:16 PM
Dr. Dan's Avatar
Dr. Dan
When I changed mine to black outs, I pulled the wheels and took the plastic shield that's under the car in front of the wheel off. Takes 45 mins/side. On the second side, I learned that you didn't need to completely remove the lens bracket, only loosen the bolts and remove the spring on top. The hardest part was getting the bolts aligned for the reinstall...hard to see in there.
Old Jul 10, 2006 | 02:59 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Manually raise the headlight remove the three screws holding the black surround on and you can reach down from the top It is a "PITA" but do able.
To Changing front turn signal unit?
