High oil pressure?
Old Jul 9, 2006 | 09:17 PM
masterchiefbt's Avatar
masterchiefbt
Default High oil pressure?
Changed my oil in my 01 FRC A4 (45K miles) with Mobil 1 10w-30 for Florida. I use a little oil (consumption issue abt 1qt per 1K) so I decided to try some oil viscosity treatment (STP) to help with the piston ring blow by. Now my pressure runs about 50 on start-up and 70 at about 3000 rpms. Is this too high? Used to run about 40 and I know adding the STP with the tight clearances in the oil pump but wondering if the pressure is too high. I don't race it but do occasionally get on it when I can. Appreciate any feedback.....
Old Jul 9, 2006 | 09:37 PM
djengr's Avatar
djengr
The oil pressure does not sound too high. I think this is the upper limit, any higher pressures you may start blowing seals and develop leaks.
As far as mixing STP and Synthetic oil, do you know if they are compatable? I remember a lesson from a seasoned service engineer. He showed us pups what would happen if you mixed al little STP with turbine oil, it turned into a ball of goo. (technical term). Make sure you don't have a ball of goo in your system find out if the two are compatable.
Old Jul 9, 2006 | 10:36 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Both Mobil and AMSOIL do not recommend adding any additives to their oils. I suggest you try an oil with a little higher viscosity before using any additives. Although only 30 grade oils meet GM Standard 4718M, I personally think the AMSOIL Synthetic 5w40 European Motor Oil is a better choice for the LSx motors, especially those being used in climates such as yours.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 10, 2006 | 08:32 AM
masterchiefbt
From what I read on the bottle it said that it is compatable with all synthetic oils. I think that I will probably drain and refill with AMSOIL maybe. I have read a lot about it and this might be a good time to try it.
Old Jul 10, 2006 | 03:22 PM
JC in XTC5's Avatar
JC in XTC5
The owners manual explicitly recommends that oil additives not be used, likely because of the tight clearances. The pressures you are seeing seem slightly high.
Old Jul 10, 2006 | 10:13 PM
C66 Racing's Avatar
C66 Racing
Wonder what they mean by "compatible"? Whatever they mean, I'm aware of no synthetic oil manufacturer that recommends using aftermarket additives with their oils.
Dropped you a PM with info on the AMSOIL Preferred Customer Program.
Old Jul 16, 2006 | 12:51 PM
superstar777's Avatar
superstar777
1st Gear
here is a very interesting article about oil additives. http://www.ford-trucks.com/article/i..._Negative.html
To High oil pressure?
