check engine light
Old Jul 16, 2006 | 01:29 PM
buffmale45's Avatar
buffmale45
Cruising
Default check engine light
How does find code as to my problem?
Old Jul 16, 2006 | 02:43 PM
JUSTAKAR's Avatar
JUSTAKAR
Default From Tech Tips
Press and hold options and then press Fuel 4 times while still holding the options button you must do this quickly. A message will appear saying "Diagonstics" then it will automatically read off the codes. Like....02-PCM(No codes)....03-BCM(No Codes)...ect. if there is a code it will look something like this 02-PCM (1052H) NOTICE THE H at the end of the code, That represents a code that has happened in HISTORY. If there is a C after the code it is CURRENT. To clear the codes let it automatically cycle through the codes then it will come to (MANUAL DIAGNOSTICS) this is where you can clear codes. Use the options button to scroll forward and the TRIP to scroll backward find the code(s) to be erased like 02-PCM (2Codes). To erase this, press and hold the reset button until it says "NO CODES" There you have done it!!!. To exit the Diagonstic menu press the METRIC BUTTON
Tech tips is a pull down menu under the other tab...or use a TECH 2 scanner.
Hope this helps
Ian
