The L shaped pin is a ZERO alignment pin. there is a small hole on the front snout. When the trans is shifted to neutral. the pin should be able to slip into the hole. If the alignment is off, you need to loosen the clamp on the shifter rod and adjust the linkage and shifter handle so that everything lines up.
I dealt with the muscle building stock B&M for about three years and then decided to put the smaller srings in that i ordered when i got the shifter. It is great. Or you can just cut the originals by one coil.
I didn't even know that was an option. I have only had the car about 2 weeks. I love the short throw. You just really have to muscle it into first and 6th.
