LS1 Oil Leak
Old Jul 12, 2006 | 03:21 PM
BadMedcn's Avatar
BadMedcn
Default LS1 Oil Leak
Guys......
My baby is leaking up a storm. It appears to be coming from the area of the rear seal. I have checked the pan, filter, etc... and it is coming from higher up in the motor. How hard is it (and how long should it take) to replace the seal? Does the motor need pulling?
Thanks for any help you can give me. Dealer has it, much to my dismay and want to be ready for their answer.
Old Jul 12, 2006 | 04:32 PM
Windshear's Avatar
Windshear
I had the same leak. I didn't add any oil between oil changes so my leak was very small. The dealer covered it under warranty. They said you don't even have to drop the oil pan to change the rear seal. This was on a Trans Am. It took one full day.
Old Jul 12, 2006 | 06:41 PM
BadMedcn's Avatar
BadMedcn
Thanks! Hopefully it is the same on the Vette. Appreciate your input.
To LS1 Oil Leak
