Shifter knob removal?
Old Jul 12, 2006 | 05:17 PM
badblackc5's Avatar
badblackc5
Default Shifter **** removal?
I poped the shift patern cap off and tried to remove the metal tab inside but could not get it out. What gives does this just pull straght up? I tried pliers with no luck it won't come out.
Old Jul 12, 2006 | 05:24 PM
BMG50's Avatar
BMG50
Welcome to the "devil" key.....it does just pull up, but sometimes it takes some doing....there is a pretty new thread that has a few pics and good ideas...do a search and you should find it...i used some vise grips on the ends and i got lucky....hth and good luck
Old Jul 12, 2006 | 09:34 PM
Roadking's Avatar
Roadking
I sprayed the Demon key with WD40 let it sit for a minute. Put towels on the shift ****. Grab the demon key with needle nose vise grips. Place a block of wood on the towel which is on the ****. Put a screwdriver through the vice grips, rest on wood block and pry up. Viola!
Old Jul 12, 2006 | 10:55 PM
Dave68's Avatar
Dave68
http://www.conceptualpolymer.com/corvette_install.htm
This method has never failed me yet and I've used it many times.
Old Jul 12, 2006 | 11:03 PM
badblackc5's Avatar
badblackc5
Old Jul 13, 2006 | 08:47 AM
craig04c5's Avatar
craig04c5
I did not put mine back in. No problem with it moving yet.
To Shifter knob removal?
