Faulty ground?
Old Jul 13, 2006 | 05:49 PM
Jackal's Avatar
Jackal
Default Faulty ground?
Do these codes sound like a faulty ground somewhere?
C1283- ????
C1288 Service Active Handling/Service Vehicle Soon Steering Wheel Pos. Sensor Faulty
B0516 Speedometer Signal Circuit Malfunction
U1096 Loss of Communication with IPC
U1064 Loss of Communications with BCM
U1016 Loss of Communication with PCM
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
Old Jul 13, 2006 | 08:36 PM
SpeedyZ's Avatar
SpeedyZ
Could very likely be a ground issue. Bad grounds can cause all kinds of strange problems! But from looking at those I'm not sure if you may not have another problem, like voltage or battery. You didn't list if the codes are current or history, or which module they were received from. Check them again, write them down, clear them, and drive it a bit and see what codes come back. Post the codes that return. May take a bit of driving to get them to return.
Old Jul 14, 2006 | 11:24 AM
Jackal's Avatar
Jackal
All of the codes clear and then all come back.
Old Jul 14, 2006 | 07:19 PM
Kevin VanSlooten's Avatar
Kevin VanSlooten
check ground under battery tighten up and clear codes see if they come back
To Faulty ground?
