P1415 while running hot, dying & surging???
For starters I haven't changed anything on my car since I did a H/C install a year or so ago (with an MTI tune). Been running great until recently.....
Recently I've been battling some surging problems at part throttle that reared its ugly head several weeks ago. I'm also having some idle surge and dying (mostly while hot). During that time I've also started throwing P1415 air injection (bank ) codes while running hot. I thought this code would get thrown at startup (i.e. while cold). I replaced the bank 1 check valve with no change, still getting the code.
I've check all the clamps between the air filter and the throttle body and I'm 99% sure there are no leaks. I've cleaned the MAF hot-wires as well but no luck. Changed the plugs, made sure all the plug wires have acceptable resistances with no luck.
At this point I'm thinking maybe the MAF or 02 sensors are shot or maybe even a vacuum leak.
Anyone have any experience with what could be left on the list of culprits?
TIA,
my brain is telling me to check the 02 sensors ..
did you say the code is only set when it's hot?
the 02s are exempt for a certain period of time while the cats warm up .. at that point if the 02s aren't working properly, well, you get a code.
and if not the 02s .. maybe the wiring for them.
good luck.
Replaced the fuel filter as well just to be thorough.
Took it for a spin, not sure if its fixed or not. I think it is but then again it seems like its still surging a bit but maybe this is my mind playing tricks on me.
We'll see how it goes over the next few days.
.. if the code is gone then i'd say the one problem is solved.
We'll see how its goes tomorrow after I can get some more miles on her.
Thanks....
Dave
Dave
OK, so replacing the O2's, didn't help at all.I haven't had another 1415 code but its still surging at light throttle especially on decelleration.
I've put the stock intake back on, no change.
I've triple checked the connections between the MAF and the throttle body, no change.
Replaced the O2's, no change.
Replaced plugs, no change.
Switched back to stock plug wires, no change. (except I destroyed one of my current ones....
)Replaced fuel filter, no change.
Check briefly for obvious vacuum leaks and don't see any.
Seems like the only thing I haven't done that I'm aware of is to replace the MAF.
Anyone else have any ideas from personal experience?
Is there a common list of places to check for vacuum leaks?
TIA,
TIA,
The drama continues.....today for the first time the car thew two IAT codes. Found a broken wire inside the connector at the IAT. Fixed that....and maybe...just maybe....my surging may be gone.
That being said, the stupid 1415 came back while hot. I've replaced the O2's and the check valve on bank-1. Guess I need to see if the pump is working or not.
