Driver side window help
Old Jul 16, 2006 | 02:58 PM
1230'sc5's Avatar
1230'sc5
Cruising
Default Driver side window help
The window stopped operating yesterday, does anyone know exactly which fuse provides power to it, the manual is not exactly clear.
If the fuse happens to be ok, what is the next logical place to look?
Thanks...
Old Jul 16, 2006 | 03:13 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
check the contacts on the switches and the motor gear. if the motor gives you a clicking sound and feels hot it is time for a new one.
Old Jul 16, 2006 | 05:33 PM
Gene Wolf's Avatar
Gene Wolf
Another way to tell if the motor is getting any juice is to turn on the headlights at night and then try the stuck window. If the lights dim slightly, then you know it's getting juice but it must be mechanical problems (this happened to me). You can also see a slight voltage dip from the voltage gauge.
No dimming or voltage dip, then you've got electrical problems you'll need to trace......Look at the fuse box. I believe it told me which one was for the driver's door window
To Driver side window help
