Buy programmer or pay a tuner?
So far, It's got Corsa exhaust, power coupler, and Blackwing air that the new code might be able to take advantage of.
Last edited by CanUSay2K; Jul 16, 2006 at 10:50 PM. Reason: Misspelled word in title
I met with Chuck at Corvettes of Westchester..he took the time out from his day to explain each and every option I will have in tuning my car and also why he felt different things should be done etc...hes local to me but you can perhaps find someone local to you or mail your PCM to him and he can just program it based on what mods you have done and send it back to you...
My two cents...hope that helps...
Quimbo>>> go back to bed, the sun isn't even up yet!
Hi Mike did the ROOSTERS wake U up this morning? My alarm clock got me up this morning at 4am. Im here at the college running the A/C Chillers!!!
Today here in NYC we are going to have TEMPS around 105
QUIMBO
SEEYAAAH
QUIMBO
SEEYAAAHThe Roosters went to Lake Erie for a fish fry
We're supposed to be 95 plus, NYC oughta be fun the way the buildings hold the heat!
MIKE
I hate this hot weather Metro detroit is supposed to be 95 I will have to start my car 10 minutes before going anywhere so it will be tolerable inside my DD.My Vette is tripple black so it is going to sit in garage until weather comes down because I dont want a tan line on my butt checks!
Bryan really seems to know his stuff and has great customer service as well....
Considering the minor difference in price between a handheld tuner and a professional tune....I'd strongly think about getting the tuning software myself (as you have done) and learn how to do it myself.
In the meantime, I could use the software to do all of the things a handheld can do, plus a lot of things a handheld can't do, due to its limitations.
I had a Predator for a little while......not worth the money in my opinion.
Hey man.....
If you're interested in tuning.....don't waste your time with hand helds....They do very little....almost nothing. If you have questions, you can call me any time....I'll be happy to answer your questions and explain how, what, and why I tune the way I do.....In our shop we use the two best products....HP Tuners and EFI Live. You CAN feel the difference....
Call me any time if you wanna know more....
Chuck CoW
The Vette Doctors Inc. (631) 841-0779
with Quimbo give Carmen a buzz on the land line he is always willing to talk to anyone about there cars and answer all questionsZEEULATER
I totally disagree.
With my Predator, I:
changed the fan settings,
firmed up my A4 shifts.
quickened the shifts
Reprogramed the WOT shift points after a rear axle ratio change
removed torque management
Tuned my AFR (using an Innovate WB sensor setup)
tested for spark knock
Monitored IAT temps
and have used it on many other vehicles for fault code diagnostics.
Stock 02 C5 A4with these following mods:
*3.42 rear ratio (still using stock TC and factory tires)
*Predator changes
*Z06 air bix lid
*drop-in K&N OEM -type- filter
I can make changes at-will... running one program on the street, and another at the track (all without making an appointment and possibly paying more fees).
For me, the only difference between the Predator and a dyno tune is that Diablosport got my money, and the local tune-shop didn't.
I do agree that with a manual shift C5, there isn't as much to gain with a handheld programer.
Monitored IAT temps
*Predator changes
*Z06 air bix lid
If you like tinkering with things and will spend the time to figure out how each table works and precisely dial in the fuel/timing than I'd buy one. I can tell you if I could have gone back and paid $500 to have my car tuned correctly I probably would have. The problem is most tuners don't do a complete tune. We have worked many hours and have over 300 tunes to perfect different tables to work with different TB/intake and cam combos. IMO, 50% of the tune is within the Air/Fuel and the timing, the other 50% is driveability and the accuracy of the tables. I've had at least 5 guys that came for a retune leaving saying that the driveability and mannors of the car was better than the stock setup but I can tell you, you can't just take a table and multiply it by x%. The PCM uses what we call compound tables where one function is based off of 4-6 tables We have over 300 different tunes on my 6 speed to determine how to make cars that shouldn't be driveable purr like a kitten.
Phil
