Coolant system flush
Old Jul 16, 2006 | 11:58 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Coolant system flush
I know the procedure but is there something specific to use to flush out the system
Old Jul 17, 2006 | 07:39 AM
Garibaldi's Avatar
Garibaldi
I have no idea if items like Coolant System Flush have a negative effect on LS1s, but I've stopped using them because they ate up three water pumps in a Honda I had. I changed the coolant in June, and in August I replaced the pump. Like I said, there may be no problem with LS1's, but I thought you might want a heads up about the possibility.
GB
Old Jul 17, 2006 | 09:04 AM
pewter99's Avatar
pewter99
thanks thats kinda what I was wondering..
Old Jul 17, 2006 | 09:38 AM
MattB's Avatar
MattB
The service manual says to use only water, for a flush it says just to cycle water through the system until it comes out clear (that is drain and refill with water several times). It say NOT to use a chemical flush.
Old Jul 17, 2006 | 12:04 PM
Oldvetter's Avatar
Oldvetter
The service manual also says there is no need to flush the system IF the collant is clean.
Old Jul 17, 2006 | 09:27 PM
cenzo's Avatar
cenzo
And where does one get de-ionized water?
Old Jul 17, 2006 | 09:38 PM
Garibaldi's Avatar
Garibaldi
Most Pharmacies have de-ionized water.
GB
Old Jul 17, 2006 | 10:14 PM
Tigershark3's Avatar
Tigershark3
GB
Also known as distilled water. Groceries, drug stores, WalMart, etc. Usually less than $1 per gallon.
To Coolant system flush
