Selecting a rear-end ratio, advice please
Old Jul 17, 2006 | 08:21 AM
Darion's Avatar
Darion
Default Selecting a rear-end ratio, advice please
Ok, so i would like to make some quarter mile runs this year, ran once, and I am looking at changing my rear-end to get the most out of my car.
What I have;
2004 coupe with a six speed, 3.42 rear-end
Haltech Stinger
Borla stinger cat-back
No other engine mods or power adders at this time.
Will be adding long tube headers and an X pipe with highflow cats
Considering switching over to a Honker intake
Tune
So keeping that in mind what would be the best ratio considering the setup I will have? I am not looking to do a cam/heads package and F/I is also out.
One last thing. Ran the car once and didn't have to shift out of fourth to clear the quarter mile. If I go with 4.10s will the gearing be so short that I have to shift to fifth to clear the quarter, which will slow me down a bit, extra shift? If this is the case can I compensate by raising the redline? How much can you raise the redline safely on a stock long block without causing valvetrain problems?
Thanks very much in advance for the information,
Darion
Old Jul 17, 2006 | 08:54 AM
c-5-steve's Avatar
c-5-steve
What I have;
Haltech Stinger
Tune
Darion
would you like to sell your 3.42s? If so how much?
Old Jul 17, 2006 | 09:44 AM
Tsab's Avatar
Tsab
4:10's will give you the best Et's for the most part. For the Mod's you are going to do and considering that you will not be spinning the engine to 7k I would opt for 3.90's for the best compromise.
Old Jul 17, 2006 | 01:35 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
go with 3.90's or 4.10's. i am running the 3.90 in my z06 with an mn12 in it and it is great. this is for a z06 mn12 but 4th gear is the same in mn6 cars so that will tell you if you will need to shift or not. you can also plug in your mn6 gear ratios also and that will tell you everything you want to know about speed and rpms for each gear. http://www.xse.com/leres/bin/gearrat...mference=82.00
Old Jul 17, 2006 | 01:41 PM
1965imp's Avatar
1965imp
Old Jul 17, 2006 | 02:57 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default 3:90/4:10?
My vote is for 3:90's or 4:10's.
I just put a 4:10 rear in my FRC (had 3:42's) and I love them.
Bob K.
Old Jul 17, 2006 | 06:46 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
3.90's all the way.
Old Jul 17, 2006 | 07:41 PM
Jeff Jeff's Avatar
Jeff Jeff
I have 4.10's, if I did it again I would go with 3.90's or even 3.73's. Too much shifting, you are in 5th gear at 45 mph.
Old Jul 17, 2006 | 08:17 PM
Darion's Avatar
Darion
Thanks for the information and the calc. is a great tool. Using it I was able to see the difference between the different ratio's and also the difference that tire size will make also. I was surprised to see how much difference slight changes in tire height make for MPH at redline. I am leaning toward 3.90's because it seem as if I can get the most flexability considering all aspects.
Thanks again,
Darion
Old Jul 17, 2006 | 08:19 PM
Darion's Avatar
Darion
Thanks to all for the information that has been posted, keep it coming please. Although I am leaning toward 3.90's I am still a bit on the fence.
Darion
Old Jul 18, 2006 | 02:03 AM
JustinStrife's Avatar
JustinStrife
I want to do 3.90's in my A4, but since I have the 2.73's, what I've heard tells me it's too much $ and too much work to really make it worthwhile, and was told it made more sense to go 3.42's
Old Jul 18, 2006 | 06:08 PM
fdxpilot's Avatar
fdxpilot
Since you have a 2.73, you have two choices, as other gears will not fit in your case. Choice 1 is to get another rearend with whatever ratio you want. Choice 2 is to send your 2-series rearend to DTE. They are the only shop that will rework a 2-series rear to accept other gears. As far as I know, the 2-series rears are not any more money from DTE with the gears of your choice.
Of course, with 3.90s, your A4 will be at almost 2700 rpm at 70 mph, and if you run the 1/4 mile, 3rd gear will only go to 118mph, unless you up the rev-limiter. IMHO, 3.42s are the best bet for a DD A4.
To Selecting a rear-end ratio, advice please
