Techron and code P1415
Old Jul 19, 2006 | 02:06 PM
9T3JIM's Avatar
9T3JIM
Default Techron and code P1415
Was wondering if Techron can damage the O2 sensors? I have a 1999 FRC with 13k on the clock, once a year I pour a bottle of Techron in the tank which I did on Monday and today the car set a P1415 code which indicates an air problem on the right cylinder bank. Could be check valves or possibly o2s. If it were o2s doesn't that set another code? Any thoughts? TIA!!!!!!!!!!!!!!
Old Jul 19, 2006 | 06:52 PM
Dave68's Avatar
Dave68
If it is a check valve, then no, the Techron has nothing to do with it.
Old Jul 19, 2006 | 07:52 PM
9T3JIM's Avatar
9T3JIM
I rechecked my codes and P1415 is listed as Bank 1 which I believe is the driver side, am I correct so far? I disconnected the hose from the check valve and determined that the air pump is working. I then removed the check valve off the air tube pipe and blew into both ways and air only flows one way. Does anyone know how this check valve works, is it working properly?
Old Jul 19, 2006 | 07:55 PM
SnowyATX's Avatar
SnowyATX
I believe I just finished battling my 1415 code. I replaced the check valve and it continued to happen. I replaced the O2's (for other reasons) and the code hasn't come back (knock on wood). And of course I added Techron recently....hmmmmm.
Old Jul 19, 2006 | 08:40 PM
9T3JIM's Avatar
9T3JIM
Did you replace all four O2s or just the driver side?
Old Jul 19, 2006 | 08:42 PM
craig04c5's Avatar
craig04c5
How much and how often are you guys using Techron?
Old Jul 19, 2006 | 08:57 PM
SnowyATX's Avatar
SnowyATX
I frigging jinxed myself. I set another 1415 a while ago. I replaced the two front O2's. My rears are turned off. I guess at this point I still have some diagnostics to do.
Good luck on yours.
Old Jul 19, 2006 | 09:29 PM
9T3JIM's Avatar
9T3JIM
Thanks for your help! I was really hoping that it would be the drivers side so wouldn't have to yank the intake.
To Techron and code P1415
