Turn signal?
I have replaced the Hazard switch as well!
we'll check it and get back
I hate electical gremlins....
Thanks for all the suggestions so far!
2 4 5 across the top and
3 1 across the bottom (verify with the pin #s on the relay)
1 and 5 should always be hot (come from the approach fuse),2 is ground only when the key is on,brake off,etc.(for DRL) 3 goes to the signal light, and 4 comes from the hazard flasher. You can bypass the whole DRL setup by leaving the relay out and jumping 3 to 4 with a short wire. Does the signal light work then?
The brake lights and the tail lights work, and the light shuts off when the blinker is engaged for a right turn. So it seems as though the BCM is telling the tail lights to turn off so that the blinker can go active, but the blinker just isn't sending power to the back.
I'll try your suggestion tonight and see if it helps. Once again I really appreciate the help.
Jay
Could it be the turn signal malfunctioner switch?
I used to be able to spray contact cleaner in the steering colomn and it would work for a little while. Now pretty much nothing.
Thanks for the input
Jay
-remove each right rear bulb,connect a voltmeter between each signal light socket terminal(dk green wire) and ground, turn the signal lever on, and measure the voltage.
-if it alternates between 0 and 12 volts, shut the signal off and measure for continuity between the ground terminal of each socket(black wire) and ground. If it's open find where the wiring between the socket and ground401 is interrupted(numerous electrical problems relate to corroded ground splices) and repair it. If it's continuous, try a different bulb or make sure the bulb is making good contact with the terminals.
- if it does not alternate between 0 and 12 volts, trace the wire back to the wiring connector C209 and check fo alternating voltage at the dark green wire terminal there when the signal lever is turned on. If still not, it suggests replacing the turn signal switch.
According to the wiring diagram, working backwards from the taillights the wiring goes to the turn signal switch, then to the hazard warning switch, then to the hazard warning switch or stoplight switch.
Sorry, that's all I got.
Jay(coincidentally also!)
--Good info BTW
