QA1 shocks
Old Jul 20, 2006 | 11:58 AM
billiardcue's Avatar
billiardcue
Default QA1 shocks
Anyone tried the QA1 double adjustable (bump & rebound) shocks.
I am considering two for the front for adjustibility at the drag strip. Have '04 Z06 shocks all around now.
They should also be nice for hiway driving by setting a little softer than the Z06 shocks.
Not cheap - Summit gets $357 per shock.
Old Jul 20, 2006 | 04:26 PM
steponc's Avatar
steponc
St. Jude Donor '14
Default Qa1 Shocks
MSI, a supporting vendor, handles them. Talk to Mark, he is a track junkie and can tell you if they will meet your needs.
Step-on-C
Old Jul 20, 2006 | 04:36 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I thought about going from the single to the double until I priced them. I found them for $339. still too much
Old Jul 20, 2006 | 05:41 PM
billiardcue
Who has them for $339?
I see in your signature you use QA1 shocks - front or all four?
Where do you set them for drag racing?
I run a 6.99 heads up class at two different country 1/8 mile drag strips that do not hook and I need a tenth in short time. If I have to bite the bullet and buy these shocks I will if I know they will help.
400 rwhp - A4 - 4.10 - 3800 stall - CCWs w/ MT Streets - Z06 shocks
Car has low 60' time of 1.48 in 1000' air and low to mid 1.5x in 2500' to 4000' air at good tracks. Best I can muster at these two tracks is mid 1.6x by adding 100 lb. ballast and a full tank of gas, the extra 180 pounds is defintely detrimental to my cause.
Any help will be appreciated.
Old Jul 20, 2006 | 07:26 PM
redbob's Avatar
redbob
Default QA1s
I have had them (front only) for 5+ yrs. Used them to help hook DRs when I had them. I set them to 0 and go best short time 1.4 flat.
Old Jul 21, 2006 | 08:29 PM
billiardcue
What do you think you would lose in short time going back to stock front shocks?
To QA1 shocks
