fuel pressure gage install problems
Old Jul 21, 2006 | 11:44 PM
ss2z06's Avatar
ss2z06
Default fuel pressure gage install problems
I have recently installed a fuel pressure gage in my 02 z06 and have a problem with finding a good switched hot source. I have tried several that are switched sources and once i make contact i then have a problem where once upon first startup i no longer have power to that source. When i turn the headlights on I then get a reading but only temporarily. What do I need to do? Is there a specific source that I should be going to for this?
Thanks!
-matt
Old Jul 22, 2006 | 07:16 AM
HeadHunter1's Avatar
HeadHunter1
When I installed mine, I grabbed power from the accessory pigtail on the passenger side. Depending on the year there should be an unused harness in the passenger footwell by the BCM. Orange wire is hot all the time, yellow ignition powered and black ground. I forget the fuse size, but it was more than enough to handle the gauges and a raptor shift light.
Old Jul 22, 2006 | 08:21 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you need a source that is hot while cranking, it's been a few months, but i think i used the large pink wire off the ignition
Old Jul 22, 2006 | 04:50 PM
ss2z06's Avatar
ss2z06
Thanks for the replies! I will go down to the kick panel and run the wire there.
Thanks again!
-matt
Old Jul 22, 2006 | 09:37 PM
ss2z06's Avatar
ss2z06
I hooked the wire to the switched source, but now have a new problem. I only have power when I turn on the lights. If they are off so is the gage even though the connection is good and the connector is good as well. I am really confused. Any ideas?
Thanks!
-matt
Old Jul 23, 2006 | 08:04 AM
SteveDoten's Avatar
SteveDoten
the gage needs 2 different sources of pwr, ignition and lights; you do have 2 seperate sources?
Old Jul 23, 2006 | 09:19 AM
HeadHunter1
Are the lights on for the gauge all the time? Sounds like you may have the leads reversed. BTW: With regular gauges that have light bulbs, the dimmer will not change the gauges. Corvette uses a system that flashes the lights really fast just like an electronic dimmer at home. More time with the lights on the brighter they appear. There is a circuit board you can make and wire up which will dim the lights on the gauges with the dash lights. I can search for it if interested, it has been a long time since I installed mine.
Old Jul 25, 2006 | 12:16 AM
ss2z06's Avatar
ss2z06
Actually I had wired up the box and have it hooked up to work off of the dimmer circuit. That works fine. I believe that the problem may be on the ground side. I recently learned that if I am using a ground wire and not a chassis ground I can have this problem. I need to check further on that.
Thanks!
-matt
To fuel pressure gage install problems
