i just finished removing stock system..took me about 3 hours ..including hunting down tools and jacks stands and etc....not bad for a paper pusher by day.....any way ..i noticed the rear o2 sensors swapped sides...the right wire sensor mounted in the left sides x pipe...the left side mounted in the rights side xpipe...do they go back swapped the same as they were when i removed them??? seems weird they would swap sides...any ideas where i put the new one ...keep em swapped like factory or changed them and put left on left and right on right? thanks....and boy the dynatech supermaxx headers sure are purty...cant wait to hear em
correct, rears get swapped just like the oem setup; with the stock manifolds off, run a bolt in all 12 bolt holes to make sure the factory thread sealant is removed
ohhh...i am almost finished....7 hours total sofar ...i just have to put in the plugs ..altenator....belt....wires etc...maybe 2 hours left...and varoooom....and hopefully i tucked in the o2 sensor wires in tight enough not to get burned.........i wanna see someone install these in less than 3 hours as i have read in the forum.....yeah right!!!....anyway...it has gone w/o a hitch and bolted right up smooth and level....glad i spend the big bucks....less head aches easy for a rookie to do..........wahbah!!! i can hear em already!!
and a SUPER THANKS to the forum for all the advice!!!
just finished up....9 hours BY MYSELF...omg! does thing hall azz!! its louder than i expected but fuhshizzle...i love the sound...the corsa catbacks are rippin ......so far no codes...all smiles!!!
