P0113 and Active Handling Warming Up Issues
This moring I went to a friends garage to look into the Engine light. While going over the AH warming message came up again and stayed on for about 10 miles. It did go out before I got to the shop. We found a P0113 code. We cleared it and ran the motor. The light came back on after putting about 5 miles. I got a new temp sensor (the one that goes in the bellow just in front of the TB,) cleared the fault. Drove home with no problems. About an hour later took the car out and the check engine light came on again. Same code P0113. During this entire ordeal the AH warming would come and eventually go away. But it would take about 15-20 min for that to happen.
Can these two problems be tied together? I have the downlaod device that connects under the column to get the codes. All I'm seeing is the P0113. If there were codes for the AH systems should I be seeing them there or is there another location to download a different computer? If these are two different problems what else can be causing the P113 code? Is there another sensor I should be looking at?
This code is a Sensor Circuit High Voltage, which means the BCM is detecting a high impedance (which translates to a very low IAT temp). The high impedance is likely due to a problem with the IAT connector, not the sensor. Do a search on P0113 - there's detailed info posted recently on verifying which side of the connector is the problem, but ultimately the likely cause is one of the 2 connector wires is broken or the pin in the connector is detaching from the wire.
Since the BCM detects a very cold IAT reading, it's likely causing the Active Handling Warming message to appear as a side effect.
