ac fan not working
Old Jul 24, 2006 | 05:14 PM
htvette's Avatar
htvette
Default ac fan not working
AC works fine yesterday. Now it's not blowing cold air. The ac fan is not working when ac is turn on. The ac fuse is ok. I have the manual ac with ***** and the ac light is on (not blinking). How do I go about checking the relay? Thanks.
Old Jul 24, 2006 | 05:17 PM
htvette's Avatar
htvette
By the way, I am not getting any codes.
Old Jul 24, 2006 | 06:22 PM
htvette's Avatar
htvette
Tried swapping relay #34 and #36, no luck. Is there a low pressure switch that I can bypass to see if the compressor is working?
Old Jul 26, 2006 | 11:24 PM
RODMAN1966's Avatar
RODMAN1966
Same problem here, anyone with the answer, if I ground the out side caseing of fan motor the motor runs at high speed.
That is is the only way I can get fan to work??
Old Jul 26, 2006 | 11:39 PM
Bill Dearborn's Avatar
Bill Dearborn
Htvette and Rodman,
I can send both of you a copy of the blower motor diagnostic and a schematic in MS Word. Send me your e-mail addresses to billdear@stny.rr.com and I will send it out to you.
Bill
To ac fan not working
