FAST intake question
Old Jul 25, 2006 | 03:34 PM
4THTOY's Avatar
4THTOY
Default FAST intake question
I am installing ported LS6 heads + a 222/228 114 cam on a LS1, I already have an LS6 intake, portaed TB, and LT headers, should I add the FAST 78 mm intake? What gains do you think I will see form this? (I was told by the shop the 90MM TB is overkill and will hurt my low end)
Old Jul 25, 2006 | 03:46 PM
ArKay99's Avatar
ArKay99
I have one on my car, and had it ported by Tony Mamo. My low end is really stout and I have a very cam as you. I have over 350ft/lbs of torque from 1500rpm's and above. Not all of it came from the manifold, but the whole combo works well together. Keep in mind, a FAST 90, NW throttle body(if you can find them, LGM?), and porting will cost you a lot, but if you want the most out of your setup and the rest is done right you will make good power. I did 26rwhp and 18rwtq from an LS6intake with ported throttle body. Your results may vary.
Another example was a friend of mine with a 2002 Z06 went with a custom cam only and FAST 78 went from 354 rwhp to to 428rwhp. It only cost him a little less than half what my setup cost (for the intake) and I'll bet he picked up ~20rwhp.
Old Jul 25, 2006 | 08:30 PM
EVILNESS's Avatar
EVILNESS
I have ported LS6 heads 224/228 cam and and at A&A told me to go fast 90/90 so i did my car made 447rwhp and drives great. hes doing a speed density tune now should be able to pick up a few more ponies ill keep ya posted.
R
Old Jul 26, 2006 | 11:14 AM
bandit_99's Avatar
bandit_99
Personally, I would go with the 90/90 and have it ported by somebody reputable. The porting work will bump up the low end losses typically seen by these intakes on - and may be worth a few on the top as well.
I don't think the 78 is really worth the effort or the costs.
Old Jul 26, 2006 | 11:24 AM
BlueThunder2000's Avatar
BlueThunder2000
Vettaholic
I really dunno and this is the subject of much debate right now - I mean, I plan to do AFR and a mild cam in the short term future, would a FAST bring any sizeable benefit in 78 or 90 ? I tend to think that with a mild cam the 78 would be better whilst a larger cam would take advantage of the larger bore. As Arkay99 said, it depends on how coherent the whole setup is.
Old Jul 26, 2006 | 11:27 AM
willyfastz's Avatar
willyfastz
I would go with the 90/90 if not just stay with the LS6 intake. I just installed a 90/90 on a Camaro with AFR heads and a F13 cam, it picked up 23hp from the intake and TB.
Old Jul 26, 2006 | 02:01 PM
bandit_99's Avatar
bandit_99
I'm no expert, but I here is a quote from a credible source- taken from LS1Tech-
Originally Posted by Tony Mamo @ AFR
FAST 78 out of the box with a bone stock 78 mm TB worth approx. 6-8 RWHP
A well shaped epoxied stock TB worth another 3-4 RWHP on that same intake.
An unported FAST 90 set-up worth an additional 3-4 over the PORTED 78 set-up.
Tack on another 5-10 RWHP for ported (correctly) 90 mm package for the ultimate results and of course the most greenbacks spent....no surprise there. What's interesting is the gains are very similar whether you are talking about a combination that puts down 375 RWHP or 475 RWHP, but as you start stepping up from there the ported FAST 90 set-up could show you even more....airflow is at a premium once your approaching 600 flywheel HP (over 500 to the tires) and the manifold starts to become a larger and larger restriction.
Tony M.
PS....To better more directly answer your original question, a 90 mm set-up will be worth an additional 3-4 ponies over the same set-up with a ported 78 mm TB. Considering the 90 mm aftermarket TB's have come down a little in price, I would tell you just to step up and go with the 90....if you already have a Shaner or another well executed 78 mm TB, you may deem the extra 3-4 HP a 90 mm set-up could provide not worth it from a HP per dollar scenario....although while $125 per pony isn't cheap, its not a ludicrous amount to spend once you have hit all the other details (much like an EWP.....$500 gets you 5 extra ponies). Not to mention you could sell your ported 78 TB which now cuts the HP per dollar in half and IMO now makes the decision to step into a 90 a no-brainer. To summarize...buy the 90 :jest:
To FAST intake question
