X-Pipe
Old Jul 25, 2006 | 06:14 PM
MedChoice Tony's Avatar
MedChoice Tony
Default X-Pipe
Would an X-pipe stop the resonance from the H-pipe common to the manual. I'm looking at eliminating the H-pipe jingle?
Thanks,
TonyP
Old Jul 25, 2006 | 06:26 PM
TroutFisher's Avatar
TroutFisher
ya, someone posted the fix bulliten from GM, that customers may hear a "jingle" and the fix was to relace the x pipe with the redesigned one.
Or get a Borla x pipe..
Do a search you may find that same thread, but it is caused by the x pipe.
GL
Old Jul 25, 2006 | 06:55 PM
DirteeDave's Avatar
DirteeDave
Resonance and "jingle are two different things. I don't think an x-pipe will get rid of resonance but I know firsthand that it will get rid of the "jingle".
Old Jul 26, 2006 | 07:39 AM
MedChoice Tony
Sounds like a plan, I will get an X-pipe....but are all X-pipes the same as in different brands..
Thanks,
Tonyp
Old Jul 26, 2006 | 08:36 AM
byte_me's Avatar
byte_me
I have a Corsa X-Pipe along with a Corsa indy tiger shark catback...there is no jingle, but it does pop and gurgle! I kind of like it actually...sounds exotic!
I think the concept behind the different X-pipes is all the same...to reduce a lot of the H pipes noise and flow better...
Borla makes a quality part as well...
Old Jul 26, 2006 | 08:43 PM
ndirishr1's Avatar
ndirishr1
I'm using X pipes. Had Bassanti's on both my '01 6spd and '00 A4. Worked great. Have now put LTs on both and they have their own Xs. Have a X on the '01 A4 which I think is a MagnaFlow. Don't like the Corsa design. Look at it, just a simple hole in pipe and welded together. Bassanti has a true X. Compare designs before you buy as the Bassanti type should give you smoother flow.
Old Jul 26, 2006 | 09:17 PM
Gene Wolf's Avatar
Gene Wolf
I just put on the Bassani X pipes with their Street/Comp cat back system and couldn't be happier. Yes, much smoother with their X pipe, and much more power with the exhaust. I would recommend the Bassani X pipe for reducing the lack of resonance overall.
Old Jul 26, 2006 | 10:11 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
I have the Magnaflow and it works great! Very easy install. I used band clamps instead of the old style muffler clamps.
Old Jul 26, 2006 | 10:17 PM
LF97C5Vette's Avatar
LF97C5Vette
What's the "jingle" is that the rattling noise in the back I hear when i leave the line?
Dan
Old Jul 27, 2006 | 06:20 PM
MedChoice Tony
Default Borla X-pipe
Would anyone recommend the Borla X-pipe? Or are all X-pipe pretty much the same...
Tony P.
Old Jul 27, 2006 | 10:49 PM
JBACE's Avatar
JBACE
Tony P.
Tony,
I would definitely recommend the Borla X-pipe. It made a noticeable improvement in my car. However, mine is now for sale. I made additional exhaust changes and now the Borla X-pipe is surplus. See the C5 parts section for my listing if interested or PM me.
Good luck.
John
Old Jul 28, 2006 | 01:56 PM
pawngod's Avatar
pawngod
no jingle on my dynatech a4 w/x pipe just alot of RAAGGGAHHHHH!!!!
To X-Pipe
