What problems have you had since you went with bigger cubes. Here are mine.
Motor has smoked since it was installed. White smoke not black. It did it on start up mostly. Did a leak down test and it read good. It was 190 all around. So that leads me to believe it is the valve seal. So goin to replace those.
Then crank bolt has backed itself out 2x already in 2 weeks. I have applied red lock tight to the threads both times. This is a arp bolt.
Next I pulled the intake to find a ton of oil dripping out of it. Also there was oil in the throttle body and air bridge. Now I am doin a catch can. Seems like since I went with a bgger cube motor, the money never stops getting tossed at it to try to get it run correctly..
I have talked to acouple of the other big cube motor vettes here, 2 427's and 1 402, all of them are also experiencing problems. One has all the same problems I am having.
I'm not sure if you are looking for someone to commiserate with or to tell you that big cubes are not a problem. FWIW, I've had my share of issues, but none of them have been attributable to my stroker motor.
When you say "smoking" do you mean off the block or out the tailpipe?
Since you found a lot of oil in the intake, I would hold off on the valve seals until I got the intake problem solved. I have not run a large ls1 but have had a lot of big cube small blocks in the last 50 years and have not had any trouble with them that didn't occur in the small cube motors.
True white smoke is coolant but check your rocker bolts. With ported heads you need to put sealant on those bolts.
The ARP crank bolts require moly lube and 197 lbs of torque- no Locktite.
I would try updating the PCV system to 05 which means no vents in valve covers except front pass cover to TB and LS2 valley. This is the toughest issue.
I did the sealant on the bolts. Goin to try another crank bolt and see if that fixes it. Also goin with a catch can to fix the oil in the intake problem. See5, I am assuming you are the same See5 on ls1tech.com. I post under the name linn.35. Although it is not my screen name, it is a friends that lets me use it. You problaly read this same post over there.
Anyways this was just a rant post, carry on with your day...
I have a 402 motor in my car and no problems what so ever ... I did have some "reduced engine power Issues" but this was old grounds as well as bad wiring from the small flash fire I had when my original motor went BOOM!
I have a blueprinted 427 built by MTI Racing in Atlanta. I have had not a single problem after 6000+ miles as a daily driver. Your builder is soooo important.
Rant off///
Two things come to mind...
You need to get a cylinder leak down test performed (ring seal).
If you're seeing smoke on startup and you have oil in your intake why would you replace valve seal. If oil is going from you intake into your combustion chamber...that'll cause smoke. I'd put a catch can in there and run some seafoam to get as much as the carbon/oil out....if you stil l have the smoking issue then I'd look to valve seals.
As for the crank bolt...try a new one and follow the instillation instructions exactly.
I have a 383 LS1 and I experience the "smoking" issue along with oil consumption. I built a catch can last night. I'm installing it in 2 hours so I'll post tomorrow if this fixed my issue.
Well the car has smoked on start up then it would be ok, so I was always told it was the stem seals. Since the car is apart anyways I am goin to go ahead and replace them now then do it later.
I did a leak down test on the shortblock and it was 190 all around.
You did a compression test, not a leak down test... you need to do this instead of guessing.
Anyone else having issues with their motors...
Rant off///
No issues here after two years of running my 447. My catch can acquires some oil in it, but none in the intake. I cleaned my filter in my vararam last weekend and had the intake off and everything was dry. There are some tricks the better tuners are using in regards to breathers and catch cans that might help your problem. I think big cube motors if set-up right are very reliable set-ups.
