Wipers..
Old Jul 26, 2006 | 07:05 AM
jman1's Avatar
jman1
Default Wipers..
my wipers just started going nuts... i'll be driving along and they will come on by themselves... they dont go all the way up they only move a few inches and go back down... they do that for awhile then stop... they work alright when i flip the lever.....no codes either.... anyone know where to start?????
Old Jul 26, 2006 | 12:58 PM
patton's Avatar
patton
St. Jude Donor '09
been wet lately? check under motor assembly for 3 utters. squeeze them get dirt and water out. some folks have success letting it dry out. its usualy the wiper module under the motor it floods and acts crazy . if you decide to r+r the motor assembly to dry it out you can unbolt mod. and flood it with denatured alcohol a few times then let it air dry .DO NOT REMOVE THE 1 TORX BOLT THAT HOLDS THE ARM ON if you get the timing wrong the wipers will try to wipe the hood
Old Jul 26, 2006 | 09:16 PM
jman1's Avatar
jman1
where is the motor assembly?? thanks...J
Old Jul 27, 2006 | 12:36 AM
patton's Avatar
patton
St. Jude Donor '09
youre kidding right
To Wipers..
