HELP!! Car is DEAD! (i think)
Old Sep 4, 2001 | 07:26 PM
DanielALee's Avatar
DanielALee
Default HELP!! Car is DEAD! (i think)
I went to crank the Car this afternoon, and all i hear is a clicking. I immediately think it is the battery, but when checking the battery the indicator shows green. I also hear a loud buzzing coming from the computer in the passenger floorboard (BCM?). Anyway, should I run and buy a new battery first? or just have it towed to the dealer for inspection tomorrow?
This ia a 99 with almost 60,000 mile on the odo, so the battery is bound to in need of replacing?
What do y'all think?
Thanks,
Daniel
[Modified by DanielALee, 5:28 PM 9/4/2001]
Old Sep 4, 2001 | 07:27 PM
DanielALee's Avatar
DanielALee
Default Re: HELP!! Car is DEAD! (DanielALee)
BTW, the car was driven this morning with no problems...
Old Sep 4, 2001 | 07:28 PM
MitchellDavidson's Avatar
MitchellDavidson
This just happened to me. It's the bat, go buy a new one.
Old Sep 4, 2001 | 07:52 PM
ataDude's Avatar
ataDude
I think my first purchase would be a good battery charger for about $30-40.
Charge the existing battery before replacing. Then, buy a battery if it won't keep a charge.
And, if a new battery is reqd, get Optima red top for $99 at Costco or $109 at Pep Boys.
You can always use the battery charger in the future.
Just my $0.02
Old Sep 4, 2001 | 10:01 PM
The One's Avatar
The One
I concur with the above posts. Plus, I'd exhaust ALL possibilities before resorting to towing or a dealership visit! :nono:
JC
Old Sep 4, 2001 | 10:21 PM
MDT's Avatar
MDT
DanielALee,
I think that the "Green Eye" only moniters one of the cells in the battery, so you may still have a bad battery. You could try jump starting it, but I really don't like to do that. If it jump starts, then that would be a pretty good indication of a bad battery.
I thought ataDude summed it up pretty well. I think if you follow his advice you'll be up and running.
Good luck.
Mark
Old Sep 4, 2001 | 10:27 PM
steve badalamenti's Avatar
steve badalamenti
Check UNDER the battery for leaking acid. This was a fairly common problem.
Sounds like you are just due for a battery, though.
Old Sep 4, 2001 | 10:50 PM
TITANS/Z's Avatar
TITANS/Z
Check your battery cable harness, too. I had my Camaro develop rust on the cable and it prevented the car from starting, even though the battery was new.
One other time, I had the neutral switch on the clutch pedal go bad, preventing the engine from starting.
Old Sep 4, 2001 | 11:18 PM
DanielALee's Avatar
DanielALee
Default Re: HELP!! Car is DEAD! (steve badalamenti)
The positive terminal was broke and leaking acid. I think I caught the acid before it caused a big problem. Unfortunatley, there are no Pepboys around here... So I went acorss the street to Sears and bought a Diehard Gold. (I would like to have bought a Optima... :( )
Anyway the car is fine now!
Thanks,
Daniel
To HELP!! Car is DEAD! (i think)
