DIC Code P0420
Old Jul 26, 2006 | 08:48 PM
PVHolgado's Avatar
PVHolgado
Default DIC Code P0420
Low Catalyst efficiency--- Have High Flo Cats on car with my DnyaMaxx Header System-- Just got this code-- Rear cats are turned off via dynotuner-- Any ideas? Thanks in advance-
Old Jul 26, 2006 | 09:30 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
You can't turn off the rear cats , go back and tell the tuner to turn off the rear O2s since that code is for the sensor downstream (after) the catalytic converter on bank 1
Old Jul 27, 2006 | 09:24 AM
trussme's Avatar
trussme
I finally had to install 02 Simmulators due to my Hi Flo Cats, to get rid of this code..that's your "other option"...
Old Jul 27, 2006 | 07:02 PM
PVHolgado's Avatar
PVHolgado
i meant the rear O2's were supposedly turned off-- Could they be and still give me this code--if not I need to discuss this with my tuner who was supposed to shut off O2's--
Old Jul 28, 2006 | 10:26 AM
Billdog350's Avatar
Billdog350
The tuner missed some of the codes to turn off. There are tons of them beuryed all over in your ECU. In tunercat, I was able to match the code with the actual ECU setting and turn it right off "no error reporting". Worked great.
To DIC Code P0420
