dic message help
Old Jul 27, 2006 | 04:19 PM
va-c5's Avatar
va-c5
Default dic message help
the windshield washer fluid got low and i received a message on my dic that fluid was low..so i filled the tank and the message still appears when i start the car...how do i remove that message other than hit the reset button but it still comes back...... thanks for your help
Old Jul 27, 2006 | 08:42 PM
GrayC5's Avatar
GrayC5
Check the connector to the fluid level sensor on the rear of the windshield washer fluid tank to see that it clean of any dirt/corrosion and firmly connected. If this does not fix the problem, then the level sensor may need to be replaced.
Good luck with the fix.
Old Jul 27, 2006 | 09:28 PM
va-c5's Avatar
va-c5
that's good i was reaching down behind the washer resivoir and knocked the sensor out i thought i had put it back but apparentally i did not i'm off to try again now.... thanks
To dic message help
