Question about DIC indicated fuel mileage
Old Jul 27, 2006 | 05:26 PM
marco383's Avatar
marco383
Default Question about DIC indicated fuel mileage
I had an interesting discussion with my tuner today, and I'd appreciate some learned input. I mentioned to him that my newly built Procharged 427 that had just made 780 RWHP on his dyno delivered an indicated 25.1 mpg on the trip home (mostly highway, but a few blasts through the lower gears on local roads). His take was that since I was now running 75 lb/hr injectors instead of the stockers, which I believe were about 32s, the DIC mileage is no longer believable. What are the actual data inputs to the DIC for fuel mileage, and is he correct?
Old Jul 27, 2006 | 05:37 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
It does not sound logical to me, however you can always verify by doing the calculations manually.
Old Jul 27, 2006 | 06:32 PM
white90conv's Avatar
white90conv
Most of these mpg devices base the fuel consumption on the injector pulse width. With the larger injectors, the pulse width will be shorter and your mpg will appear high. There is probably some way to program the pcm to fix it.
Old Jul 27, 2006 | 06:37 PM
M_T_0's Avatar
M_T_0
the DIC takes the information from the tune via the injector flow rate table to calculate the fuel consumption via the pulse width of the injectors. as long as the table in the tune is correct then the DIC will read corectly.
but then some tuners never put the correct flow data in the table.
More Than Zero
To Question about DIC indicated fuel mileage
