CAGS harness
Old Jul 27, 2006 | 06:54 PM
thorn92's Avatar
thorn92
Default CAGS harness
I bought a CAGS harness from Mid-America and the instructions that came with it say that the sensor is located on the driver side of the transmission. Once under the car, I saw nothing on the driver side? I switched to the passenger side and found a coupler with a harness snapped in it. The couplers are identical and fit perfect. Today, the 1st to 4th light came on so I tried shifting to 2nd and it still forced me to 4th? Did I plug this into something else? Everything else runs fine and no codes. Or is this the correct location and I have a faulty CAGS harness? Any ideas or answers from those of you who have installed one? Thanks. This is a 2000 coupe by the way.
Old Jul 27, 2006 | 06:57 PM
thorn92's Avatar
thorn92
I found some other posts with some insight...sorry for not researching better the first time.
Old Jul 27, 2006 | 11:08 PM
JC in XTC5's Avatar
JC in XTC5
I guess you found that you were using the reverse lockout solenoid plug on the passenger side of the tranny.
The CAGS plug is on the driver's side about 2/3 of the way up towards the top. It's not easy to find unless you have a good point of reference.
Glad it worked out.
Old Jul 28, 2006 | 03:06 PM
thorn92's Avatar
thorn92
Got it right today...man, is it nice having control over the gears. I'm not used to a transmission being so far back...I did the usual look directly behind the motor. All is well now, thanks to this forum!
To CAGS harness
