LF wheel speed sensor
Old Jul 29, 2006 | 11:08 AM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default LF wheel speed sensor
Is it integral with the hub/bearing? or is it replaceable? and if anyone has the part number for a '98 that would be great
Old Jul 29, 2006 | 04:14 PM
thorn92's Avatar
thorn92
They are replaceable...check ebay...usually quite a few on there...part # for a 98 is 10438853
Old Jul 29, 2006 | 04:28 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Autozone/Timken/$160 for the fronts
now, are you getting a code pointing to the LF?
if yes, then swap the 2 foot harness from L to R, I had one fail on my FRC
I've swapped a lot of wheel bearings, but due to wear, they will make a lot of noise at the end of thier life
yes, the sensor is integral
Old Jul 29, 2006 | 04:44 PM
vetteman9368
St. Jude Donor '08
This happened right after i washed the car, wonder if something got wet
Old Jul 29, 2006 | 04:58 PM
thorn92's Avatar
thorn92
So Sorry Man.....my mind was thinking of the LF pressure sensor...sorry.
To LF wheel speed sensor
