NEED HELP ASAP Header install...
Old Jul 30, 2006 | 05:06 PM
5W0P3's Avatar
5W0P3
Default NEED HELP ASAP Header install...
I've got the passenger side in on my z06. I have stainless works headers, the directions say the driver side comes in from underneath, is that true?! It seems almost impossible for that to happen. Does it go in from the bottom or the top? anyone have any advice!?
i'm in middle of this right now, i appreciate all quick responses.
IF YOU'RE CATCHING THIS NOW... DISREGARD AND READ BELOW. HEADERS ARE INSTALLED, NO O2 EXTENSIONS. NO MODIFICATIONS, JUST A TIGHT FIT.
Old Jul 30, 2006 | 05:08 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
we put my TPIS in from the top..you need someone to gently pry the engine up a bit so you can drop them in...I dont know what all you have removed at this point either
Old Jul 30, 2006 | 06:34 PM
5W0P3's Avatar
5W0P3
I got everything in, to find out i DO need o2 extensions, when i was told i didn't. ohwell, guess i'll get to hear it tommorow
Old Jul 30, 2006 | 06:42 PM
pewter99's Avatar
pewter99
well...at least the hard part is done...
Old Jul 30, 2006 | 06:44 PM
pawngod's Avatar
pawngod
some headers install require the engine mount loosened and raise engine w/jack 2 inches.........just installed my dynatech..didnt have to do that......car had to be jacked up about 3 ft
Old Jul 30, 2006 | 09:03 PM
5W0P3's Avatar
5W0P3
Well, everything is in now. I didn't need o2 extensions and everything sounds incredibly good! getting tune later this week!
Old Jul 31, 2006 | 10:54 PM
pawngod's Avatar
pawngod
tell me how the tune goes....i have complete exhaust system installed and wondering if the 500 bucks my tuner wants will be worth it or not..car seems to run perfect..cant see how a bit a tweeking the computer can make much hp
Old Jul 31, 2006 | 11:56 PM
ronman99vette's Avatar
ronman99vette
How did the install go for you other than the problem with one side? What type of lift/equipment did you use? Would you recommend it to others for a DIY project?
R
Old Aug 1, 2006 | 03:50 AM
5W0P3's Avatar
5W0P3
R
I did it in my garage. I put the car on 4 jackstands. I had one person on the driver side, one on the passenger side, me underneath, AND one more as the "gopher". Make sure you have a deep 15mm socket. You'll use it several times. Everything went smoothly, except for the driverside header. I was putting the emergency post up when he came in screaming that he got it in.
Also... GET NEW HEADER BOLTS!!!!! I DO NOT care how many miles are on your car, GET NEW header bolts!!!! I now have 1 Header bolt with no head... IN my head. It shouldn't be a problem, and it doesn't leak.
I think i've put about 100 miles on it so far and pretty sure something is leaking, so when you're done... tighten EVERYTHING up... and a day or two later, go over everything again. I'm going over mine tommorow (2 days later).
You can do this in your garage. It's not that hard, but you need ALOT... and i mean ALOT of patience, and a couple friends hanging around. If you have to buy them all pizza and beer (i did) later, its well worth it, for you to say YOU did it, and save the money a shop would charge... you can do it.
oh, and make sure you have a big hammer
good luck.
Old Aug 1, 2006 | 03:52 AM
5W0P3's Avatar
5W0P3
will do, i'll get a "base" pretune pull and an after pull
Old Aug 1, 2006 | 09:37 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
LG Pros = 329rwhp before tune, 346 after.
To NEED HELP ASAP Header install...
