Does Millennium yellow have a clear coat?
Old Aug 1, 2006 | 08:45 PM
01vetter's Avatar
01vetter
Default Does Millennium yellow have a clear coat?
I have some small scratches that I need to fix. I bought some Dupont #7 pollishing compond and noted that the directions stated "not for use on clear coats" They have a special polishing compound for clear coats. My glove box only has one paint code - U423G. I would imagine if it had a clear coat that would also be listed??
Old Aug 1, 2006 | 08:51 PM
5W0P3's Avatar
5W0P3
i'm pretty sure it does, mine does.
Old Aug 1, 2006 | 08:56 PM
01vetter's Avatar
01vetter
Why is there only 1 paint code? Shouldn't there be 1 for the clear coat?
Old Aug 1, 2006 | 08:58 PM
Mike Mercury's Avatar
Mike Mercury
are you asking if the clear coat is tinted or not ???
5W0P3's Avatar
5W0P3
I think thats just to differentiate the colors. As far as I know everycar that GM made in the last 20 years, had clear coat. Unlike Ford.
Old Aug 1, 2006 | 09:01 PM
01vetter's Avatar
01vetter
Tinted or not, I just need to know if it has a clear coat so I can get the right polishing compound.
Old Aug 1, 2006 | 09:06 PM
c4cruiser's Avatar
c4cruiser
IIRC, the clear coat for the extra-cost MY paint has a yellow tint to it. A compound for clear coats would be the one to use.
Old Aug 1, 2006 | 09:12 PM
01vetter's Avatar
01vetter
c4cruiser, Thanks! Now lets see if I can restore the finish!
Old Aug 1, 2006 | 11:04 PM
mfrejek's Avatar
mfrejek
Yes it has a clear coat, like already stated, about every GM car for the last 20 years is base coat, clear coat.
Old Aug 1, 2006 | 11:06 PM
Mike Mercury
and a few optional colors for the C5 had tinted clear coats.
Old Aug 2, 2006 | 12:10 AM
bigbadbevo's Avatar
bigbadbevo
MY has a TINTED clear coat.
Old Aug 2, 2006 | 01:16 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
From my understanding it does not have tint in the clear coat. It is a 3 stage paint prossess. Base coat, tint coat, and clear coat. A 2 step process like most other colors would be a base coat and clear coat.
Old Aug 2, 2006 | 07:33 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Called a friend of mine that owns a shop and the answer is YES. Our Millennium Yellow Corvettes are clear coated...
Old Aug 2, 2006 | 07:58 AM
AU N EGL's Avatar
AU N EGL
Millenium Yellow has a Gold tinted clear coat.
Old Aug 2, 2006 | 03:23 PM
C5XTASY's Avatar
C5XTASY
Ed
Old Aug 2, 2006 | 03:52 PM
2kbluestreak's Avatar
2kbluestreak
From what I've read here, Millenium Yellow and Magnetic Red both had tinted clear coats and cost extra.
Old Aug 2, 2006 | 04:23 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
MY has a tint base coat, a color coat, and a standard clear coat.
From the factory, there is no tint in the clear. It got the same clear every other car and color got. This is straight from GM documentation.
However, the aftermerket paint systems all attempt to duplicate this color in a 2 stage bc/cc process, and a trick I've heard that aids in color-matching is to mix a slight bit of yellow into the final cleacoat. This is not the way it was originally done though.
To Does Millennium yellow have a clear coat?
Old Aug 2, 2006 | 10:58 PM
01vetter's Avatar
01vetter
Why does my glove box only have 1 paint code - U423G, which I believe is the clear coat? Shouldn't there be 2 or 3 codes?
Old Aug 2, 2006 | 11:05 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
The GM paint cose for MY is WA-423G. Anyone who looks that spec up through a paint manufacturer will get a list of all the materials needed to match the Millenium Yellow paint color.
They don't issue a paint code for each individual coat...that is the paint code so the color can be identified and matched later on. As stated above, all GM cars in the past 20 or so years use base coat/clearcoat paint systems. There is no paint code for clear...clear is clear, and an essential part of the process.
Old Aug 2, 2006 | 11:17 PM
djengr's Avatar
djengr
Just one code, that is for mil yellow. The top coat on mine seems to be just a standard clear. Someone recently posted a website that gives all the paint codes for corvettes.
I have had good luck on using meguiars fine cut cleaner #2 for scratches, followed up with a good wax.
