PCV Replacements
Old Aug 2, 2006 | 06:48 PM
cazvette's Avatar
cazvette
Default PCV Replacements
Does anyone know where i can get PCV replacement parts . I need an elbow 3/8 section.
Old Aug 3, 2006 | 12:06 AM
RL Vetteman's Avatar
RL Vetteman
Default Sounds like a trip to the Dealer
Good luck finding the elbow only. Had to replace mine on my wifes car because it had a gaping crack causing hesitation and had to buy the whole assembly from the Chevy dealer. Autozone nor Checker carried the part.
Old Aug 3, 2006 | 01:55 AM
Chris.Shea's Avatar
Chris.Shea
vette2vette look on the bottom left 3 from bottom. used and cheap plus you may be able to get just the one part. if you have to get the whole thing ill pay you for the valve (rubber from intake manifold to the plastic tube) cause my rubber is breaking down and now has a pinhole in it.
Old Aug 3, 2006 | 06:51 AM
see5's Avatar
see5
You would be better off to get a LS6 valley cover and plug the two vents on the rear of the valve covers. This is the 04 configuration.
Old Aug 3, 2006 | 08:21 AM
cazvette's Avatar
cazvette
I was affraid that I would have to buy the whole assemebly. It's ashame because they want 65$ for it when all i need is a part that probably cost 2 bucks.
Old Aug 3, 2006 | 08:26 AM
see5's Avatar
see5
You are talking about the line that runs between the rear of the valve covers?
Old Aug 3, 2006 | 04:21 PM
cazvette's Avatar
cazvette
Yeah, its' just the elbow that runs at the back of the valve covers. I ended up buying from GM for 50 bucks , i just want to fix the darn thing asap.
To PCV Replacements
