Your opinions on this please
Old Aug 3, 2006 | 10:00 PM
402Sam's Avatar
402Sam
Default Your opinions on this please
I pulled the intake and it was coated in oil as well. If you dont know this is the piece that connects the throttle body to the air bridge. I was getting smoke out the exhaust on start up. It wouldnt smoke after 5-10 seconds of runnin. So I first thought it was valve seals. I pulled my intake to replace the seals and I saw this. So I call my friends performance shop and they say that I need a catch can. They say a catch can will solve my smoking problem. I know a catch can will catch and keep the oil out of the intake from the little blow by that I am getting. Would this be the reason my car smokes on start up. If so why does it stop smoking after it runs for a min. I did a compression test and the block checks out ok.
Opinions???
Old Aug 3, 2006 | 10:31 PM
Vassili's Avatar
Vassili
last time I had something like that up in my air intake area, it was the head gasket.
Old Aug 3, 2006 | 10:38 PM
402Sam's Avatar
402Sam
A blown head gasket???? I just put on new triple steel cometics head gaskets.
Old Aug 3, 2006 | 11:10 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
I agree with your shop, a catch can should solve your problem. My car puts about 1-2 ounces of oil in there over a few months of very hard driving. If not for the catch can.. it would be in the intake, the same as yours.
There is no reason that a blown head gasket would put oil into the intake manifold like that... and you said you checked compression. You could also do a leak down test. I suspect you are just seeing normal venting.
I also vent the valve cover on my car. Mine is forced induction though.
I use the AMW catch can. Not cheap, but very nice.. about $200 with the bracket.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Aug 4, 2006 | 09:59 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Get a catch can installed as soon as possible, I run my FI setup the same with the AMW catch can and the breather like ECS uses and I do not get any oil in my intake and last weekend my car was abused frequently in boost and my catch can did not even have a 1/2 ounce of oil in it
Old Aug 4, 2006 | 10:09 AM
02gt350's Avatar
02gt350
is this catch can for FI cars only?
Old Aug 4, 2006 | 10:24 AM
WKMCD's Avatar
WKMCD
I don't think it's head gasket but FYI, I had Cometics blow twice on mine. I'm running stock GM gaskets now with no problems.
Old Aug 4, 2006 | 11:16 AM
Face's Avatar
Face
Nope!
Old Aug 4, 2006 | 12:13 PM
BLOWNZO6's Avatar
BLOWNZO6
I am really of the opinion that this is the way to go. They are cheap too.
Old Aug 4, 2006 | 04:05 PM
402Sam's Avatar
402Sam
Catch can is being installed tonight. Thanks for your answers.
To Your opinions on this please
