Overheating...
Old Aug 4, 2006 | 04:35 PM
WildWolf's Avatar
WildWolf
Default Overheating...
I have a problem with my car.....every so often (once or twice a year), my water temps and oil temps rise to astronomical levels. 250+!!!! It doesn't do this often and happens when I am in traffic. Once the car hits the open road, the temps come back to normal. What should I look at? Should I flush the coolant system? Do I need to add water to it? Thanks in advance
Old Aug 4, 2006 | 05:02 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Start by cleaning your A/C condenser and radiator, which is aft of the A/C condenser. Pull the top cover and carefully blow out the fins with an air gun that has a long snout. You'd be amazed at the amount of junk that collects there.
Old Aug 4, 2006 | 05:04 PM
flybyyou's Avatar
flybyyou
You might also want to upgrade the radiator
Old Aug 4, 2006 | 06:06 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
If you go to Home Depot and ask for a dryer vent brush it is less than $5 and does a great job....its real long and skinny works great
Old Aug 5, 2006 | 10:49 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Josh, next time that happens ck the fans, with the hood open you'll be able to hear them or at least feel the air moving
doesn't hurt to ck the front of the rad from underneath, acts as a vacuum
To Overheating...
