Got LS2 Heads... How do I clean them?
Old Aug 5, 2006 | 02:34 AM
MUKAK's Avatar
MUKAK
Default Got LS2 Heads... How do I clean them?
I cleaned most of the Carbon build up with a razor (flat surfaces) but how do I clean the Valve areas where the Cylynder bowls are????
anything I could buy from PEPBOYS (engine degreaser etc)...
thanks a lot
Old Aug 5, 2006 | 08:45 AM
willyfastz's Avatar
willyfastz
I use Greased Lightning, seems to work pretty good.
Old Aug 5, 2006 | 09:35 AM
vettenuts's Avatar
vettenuts
Disassemble and ultrasonic cleaning, that's what I did on my new Darts after I cleaned up the ports a tad.
Old Aug 5, 2006 | 12:35 PM
MUKAK's Avatar
MUKAK
where do i get this stuff?
Old Aug 5, 2006 | 06:11 PM
MUKAK's Avatar
MUKAK
ttt
Old Aug 6, 2006 | 12:10 AM
muncie21's Avatar
muncie21
Try a Scotchbrite pad next time, razors (metal ones at least) aren't the best for aluminum heads.
Old Aug 6, 2006 | 01:19 AM
Billf6531's Avatar
Billf6531
Drop them off at your local auto machine shop, and have them hot tank them.
Old Aug 6, 2006 | 02:47 AM
MUKAK's Avatar
MUKAK
is this safe to do with Valves and springs on the heads?
thanks
Old Aug 6, 2006 | 08:14 AM
ArKay99's Avatar
ArKay99
I used Top Engine cleaner. You have to soak the head for a while and the stuff is vile, but it works great. I used a big bucket, poured 2 cans of the stuff over the heads, and covered it while it was in the hot sun and let it sit all day. Every 1/2 hour or so I uncovered them and 'basted' them. When the time was up I removed them, hosed them down, and they were as clean as new.
One thing I thought I should mention. I read in the manual not to use a ScotchBrite pads. The reason given is it creates such a fine dust that the oil filter can't remove it and 'engine damage' can result.
Having said that, I've read of lot's of guys that have used it with no problems.
Old Aug 6, 2006 | 10:38 AM
C5-JIM's Avatar
C5-JIM
Use oven cleaner, it wortks great.
C5JIM
Old Aug 6, 2006 | 03:05 PM
Billf6531's Avatar
Billf6531
Should be, it's all metal. But since the heads are off, it's an ideal time to disassemble everything and check for bent valves, worn seats, out-of-spec springs, etc. It's easy to do now, and the cost is essentially zip. Much more work later, if things are not as they should be.
thanks
Old Aug 6, 2006 | 10:14 PM
MUKAK's Avatar
MUKAK
should I PORT & POLISH them? MILL them?? how much to mill off??
thanks
Old Aug 7, 2006 | 10:24 PM
MUKAK's Avatar
MUKAK
ttt
To Got LS2 Heads... How do I clean them?
