Clearing codes for inspection
Old Aug 5, 2006 | 06:24 PM
ckgunn's Avatar
ckgunn
Default Clearing codes for inspection
Is there a way to clear the codes long enough to pass a state inspection?
Old Aug 5, 2006 | 07:17 PM
Darkness's Avatar
Darkness
You can clear codes but then it will show that the car is not ready for testing and they're going to tell you to go back in a week. What kind of codes are they anyhow?
Old Aug 5, 2006 | 07:22 PM
Rogue Leader's Avatar
Rogue Leader
St. Jude Donor '08
Yep I thought I'd be a smartass and clear mine before inspection and I ended up failing..... Went back a week alter and passed.
Old Aug 5, 2006 | 08:00 PM
Rick@CTCORVETTE's Avatar
0Rick@CTCORVETTE
Former Vendor
It sounds like the test is different from state to state. We use a standard obd2 (1995+ cars) here in CT. The codes can be reset right before the test and it will pass. I've done this on two cars that I own and it worked, even though most said that it wouldn't.
To Clearing codes for inspection
